e23 and e27 - Page 4
Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 66
HT4100 4.1, 4.5, 4.9 Discussion, e23 and e27 in Cadillac Engine Discussion; thanks for all the help, if/when it breaks again, i know where to come ask......
  1. #46
    Reverend Hearse's Avatar
    Reverend Hearse is offline Cadillac Owners Member
    Automobile(s): 1984 Collins hearse, 1979 Coupe , 1984 Seville,1990 fleet'
    Oct 2010
    32
    86
    Re: e23 and e27
  2. #47
    Oct 2010
    32
    86
    Re: e23 and e27
    so i feel i have more of a transmission problem versus a motor problem now. when i n''D'' the motor lugs between 2-3 and 3-4 , and when slowing down it almost cuts the motor off before it down shifts. when driving in the ''3'' position, most of the issue is eliminated but not all. i only do in town driving, no interstates at all, so i never really get above 40 mph. i have a rebuilt 200-m i can pick up for next to nothing. but i want to know what your thoughts on it could be. the fluid looks fine and is at the proper level.
  3. #48
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    Re: e23 and e27
    Any codes? Possible shift solenoid or even shifter switch...I'll think on it...
  5. #49
    Oct 2010
    32
    86
    Re: e23 and e27
    I got a code 30 today , ISC rpms out of range . What is the shift switch and solenoid ? Are they internal transmission parts? The 425/400 turbo swap is lookin better by the day , but I don't thunk I could afford the gas for it on a daily basis .....
  6. #50
    Feb 2009
    Jacksonville, FL
    1,023
    Re: e23 and e27
    Ok, a code 30 might mean you need to run a TPS/ISC procedure on your car and may not be tranny related at all.
    On some of these cars (I am not totally familiar with your earlier model) they have a shifter location switch, a switch that tells the ECM what gear or gear setting the trans is in. Sometimes these switches have a meltdown or need adjustment and don't relay that info back to the ECM. If the switch lets go in the R, D, 1, 2, or 3, the motor may either lag, stall, or not even start/run. Usually that will throw a specific code, even if it just needs to be adjusted.
    The shift solenoid is a switch that actually actuates the transmission shifting. Sometimes they leak or short, causing erratic or laggy shift patterns. Again, this should throw a code.
    IMO, I would run TPS/ISC procedures and see if that solves the problem....
  7. #51
    Oct 2010
    32
    86
    Re: e23 and e27
    is there a link to the proper procedures to set the TPS and ISC?
  8. #52
    Oct 2010
    32
    86
    Re: e23 and e27
    also i guess i should add, since resetting the codes the other day, no further codes have appeared, and istill have the lugging when in ''d'' but not nearly as bad in ''3'' , what is maximum speed in ''3''?
  9. #53
    Feb 2009
    Jacksonville, FL
    1,023
    Re: e23 and e27
    how did you check the trans fluid level? The proper way is at operating temperature (warmed up), flat ground, while running, then check.
  10. #54
    Oct 2010
    32
    86
    Re: e23 and e27
    on flat ground, running , in neutral, parking brake on....
  11. #55
    Feb 2009
    Jacksonville, FL
    1,023
    Re: e23 and e27
    Ok, cool. I'm not sure on the TPS/ISC procedures for YOUR car. but they can't be that far off from the ones for the 4.9, although I may be wrong...
    Procedure listed here: http://www.cadillacforums.com/forums...0-deville.html
  12. #56
    Oct 2010
    32
    86
    Re: e23 and e27
    getting the e29, fourth gear circuit shorted.... wheres the spot where i bash my head into th wall til im in a coma???
  13. #57
    Feb 2009
    Jacksonville, FL
    1,023
    Re: e23 and e27
    Alright, that's prolly the shift solenoid...
    Typical Caddy issue, get one thing fixed, and another thing falls apart
  14. #58
    Oct 2010
    32
    86
    Re: e23 and e27
    IS THAT something i can fix or do i need a transmission shop?
  15. #59
    Feb 2009
    Jacksonville, FL
    1,023
    Re: e23 and e27
    I'd take it to a shop...
  16. #60
    Oct 2010
    32
    86
    Re: e23 and e27
    Hmm..... 65 bucks an hour vs using my spare trans w/ shift kit... Decisions....
  17. Remove Advertisements
