e23 and e27 - Page 3
Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 66
HT4100 4.1, 4.5, 4.9 Discussion, e23 and e27 in Cadillac Engine Discussion; I still say your looking at the pick up coil and at this point is worth the try and far ...
  1. #31
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    Re: e23 and e27
    I still say your looking at the pick up coil and at this point is worth the try and far less than a motor swap...
  2. #32
    Reverend Hearse's Avatar
    Reverend Hearse is offline Cadillac Owners Member
    Automobile(s): 1984 Collins hearse, 1979 Coupe , 1984 Seville,1990 fleet'
    Oct 2010
    32
    86
    Re: e23 and e27
    Screw it , I'm done. I'd rather burn the stupid thing before I spend another dime on it. Today while driving , the car shut off and would not restart. I had fuel pressure , but no spark. When i removed the coil cover the wire to the positive side was burned . I replaced the coil with a brand new one , but still have no spark . It cranks over fine and has plenty of fuel . Not even a weak spark though .
  3. #33
    Feb 2009
    Jacksonville, FL
    1,023
    Re: e23 and e27
    Quote Originally Posted by Reverend Hearse View Post
    I hear this a lot when people talk about their Cadillac
    Been there, said that myself
    CODE 23...this still points to the pickup coil...
    and the spark is controlled by the ICM...
    What people fail to understand is that car parts that sit are failures waiting to happen. You've still not changed the parts that effected you from the beginning, only another distributor from a car that sat, which (by the way) made the car run right at first. Change all the parts listed, if nothing works, then burn the car.
  5. #34
    Feb 2009
    Jacksonville, FL
    1,023
    Re: e23 and e27
    Check for blown fuses also...
  6. #35
    Oct 2010
    32
    86
    Re: e23 and e27
    pulled the distributor again today. tested the pick up coil as per my service book , with a reading of infinity, meaning it is indeed good. im going to go ahead and replace it on payday however, along with the ICM ,and that other part that looks like a condenser. i really dont know what else could be causing the problems im having , so i figure ill start completely fresh....
  7. #36
    Feb 2009
    Jacksonville, FL
    1,023
    Re: e23 and e27
    Did you spin the distributor while testing? The pick up coil breaks a magnetic field which relays info to the ICM and fuel system as to cam positioning and timing. Sometimes a bench test with a meter doesn't tell the whole story. If a resistor is burned up yet is dependent upon current to be active, then again, the bench test would say "good" to problem that would not show itself until electrified.
    Like I said before, this one is not as easy to detect and can be a little tricky....
  8. #37
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: e23 and e27
    I would buy a new distributor before i rebuilt the old one. I haven't priced out the difference but I think a new one is reasonable at around $150.
  9. #38
    Feb 2009
    Jacksonville, FL
    1,023
    Re: e23 and e27
    Quote Originally Posted by cadillac_al View Post
    It cost me $380 to by my last one...
  10. #39
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,607
    Re: e23 and e27
    Quote Originally Posted by the recluse View Post
    I can get them from the local parts store here for $88 my cost, $125 yours, lifetime warranty.
  11. #40
    Feb 2009
    Jacksonville, FL
    1,023
    Re: e23 and e27
    Quote Originally Posted by drewsdeville View Post
    WOW they saw me coming...this was about 4 years ago though...
  12. #41
    Oct 2004
    Oak Creek, WI
    5,607
    Re: e23 and e27
    Well, there could be differences in the dressing as well though.
    The $88.$125 one is the housing, shaft/rotor mounting plate, gear, and ignition module. Doesn't come with a pickup coil, hall effect, cap, rotor or coil.
  13. #42
    Feb 2009
    Jacksonville, FL
    1,023
    Re: e23 and e27
    Mine was plug n play...
  14. #43
    Oct 2010
    32
    86
    Re: e23 and e27
    today i got off early from work , so i hit the parts store. i bought all new internals for the distributor, and got it running great. even better than before. on the way home i threw a alternator belt and codes 12 , 23 , and 44 popped up . i have deciphered them to mean as follows,
    E12 - No Distributor Signal
    E23 - EST Signal Problem
    E44 - Oxygen Sensor Signal Lean
    would the lack of sufficent voltage cause these codes to pop up? i had about a 5 mile drive and th service now light came on. car still ran great, even with no charge.
  15. #44
    Oct 2010
    32
    86
    Re: e23 and e27
    replaced the belt, cleared the codes, so far so good... but its a cadillac and it knows i got paid , something is bound to happen...
  16. #45
    Feb 2009
    Jacksonville, FL
    1,023
    Re: e23 and e27
    You're welcome
    ...its a cadillac and it knows i got paid , something is bound to happen...
    I KNOW what you mean...
  17. Remove Advertisements
