Results 1 to 13 of 13
Thread: Stainless steel exhaust, 90 Deville
    daniel58 is offline Cadillac Owners Fanatic
    Automobile(s): 58 Coupe Deville, 77 Coupe deville, 90 Deville
    Sep 2009
    183
    I have a question for you guys, My owners manual (90 Deville) says that the exhaust pipes and muffler are made of stainless steel. As a machinist I know the 1st test for stainless steel is to see if it is non magnetic. Well my exhaust is magnetic and it seems to have corroded to some degree. I guess I can not complain because it has lasted for 20 years, far longer than regular steel exhuast would last in central Ohio. I'm just wondering how Cadillac could get away with calling it stainless steel when seems that its not. I would also like suggestion as to the best replacement for my rusted out stainless steel exhaust system. Thanks in advance.
    Sep 2009
    183
    Re: Stainless steel exhaust, 90 Deville
    Anyone have any comments?? I guess I'll go to Autozone and get the elcheapo pipe and a $30 turbo muffler from Jegs. It was a rhetorical question anyway I guess.
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Not all stainless steel in non magnetic. Im not sure if it is stainless or not but the piping on my 20 year old seville is still in pretty good shape. Since there is no aftermarket exhaust for our cars the best thing is to get custom job done at a muffler shop. Of course the most cost effective deal is to go with the El Cheapo.
  5. #4
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,607
    The factory exhaust was stainless. However, it's T 409, a very low grade stainless with less than 1% nickel and about 10% chromium. Over time, it doesn't hold up as well as higher grades of stainless, like T 304. Still, these Caddy exhausts seem to last quite a long time. I have a 190k 1989 Eldorado in my driveway right now with the original exhaust still hanging...and this is Wisconsin.
  6. #5
    Sep 2009
    183
    Thanks for the answers guys, I have to admit the Cad SS exhaust does last quite a while. I was wondering if there is a SS supplier, if there is its probably way to expensive for my 20 year old Deville. Elcheapo it will be with a coat of hi temp paint to make it last a little longer. The different grades of SS explain the confusion on my part.
  7. #6
    MrDobin is offline Cadillac Owners Fanatic
    Automobile(s): 1985 Cadillac Seville Elegante
    Feb 2009
    28
    222
    I second the muffler shop idea.
    Buddy of mine with a Riviera took it in to a place locally and it wasn't too costly and they did it up like the original.
    My Seville is coming up on 26 years and only issue of rusting I have had to fix in the pipes is the flange on the cat just recently which they fixed with high temperature tubing.
  8. #7
    quins90lac's Avatar
    quins90lac is offline Cadillac Owners Enthusiast
    Automobile(s): 1990 Cadillac sedan devile
    May 2008
    Peoria IL USA
    35
    616
    if you want to drop some cash buts its $15 per foot
    http://www.stainlessworks.net/cart/p...oducts_id=1265
  9. #8
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    Like mentioned, the 400 series stainless is a bit magnetic. I had to have the exhaust cross-over replaced on the wife's Caddy a few years back. The pipe was fine yet, but the flanges rusted to a point that it leaked at the manifold joints. Kinda cheesy with SST pipes and plain steel flanges. It's replaced with a plain steel muffler shop piece, and I figure it will need another one in a couple of years.
  10. #9
    Sep 2009
    183
    Thanks again for the response. quins90lac the stainless exhaust supplier is sort of what I was looking for, I'm going to look that site over a bit. Don't know if I have the equipment to work with it not to mention the cash right now but very interesting. As others mentioned the exhaust on my 90 broke around the converter flange area, I was able to fit a sleeve and pull it together, its fairly solid but it does seem thin and will have to be dealt with sooner or later. A machinist should have realized there were different grades of SS as in other metals, guess I wasn't thinking!
  11. #10
    quins90lac's Avatar
    May 2008
    Peoria IL USA
    35
    616
    before or after the converter. Mine keeps on breaking before the converter so i just put in a reducer and some flexible exhaust tubing. The tubeing usaly last about 2 years then it with rust out.
  12. #11
    Sep 2009
    183
    I think mine is just after the converter, I have a box of adaptors and sleeves that have collected over the years and was able to fit a sleeve with a little exhuast putty and clamps. Regular steel will rust out completely in 2 or 3 years on a daily driver parked out side here in central OH. The SS exhaust on the Caddy was one of the selling points for me. I just wonder how long true high quality SS would last, probably longer than the car. They really should use SS more on new cars particularly fuel lines with the high pressures of fuel injection.
  13. #12
    Oct 2008
    Palm Bay, FL
    2,024
    Next time you need 'exhaust putty' try Permatex orange RTV. Good stuff.
  14. #13
    quins90lac's Avatar
    May 2008
    Peoria IL USA
    35
    616
    Yeah i know i live in IL and let me tell ya the mid west is just hard as heck on cars. Right now I'm in the slow proses of trying to fix all the rust on my car.
  • You may not post replies
