UGH watter pump gasket
Results 1 to 15 of 15
HT4100 4.1, 4.5, 4.9 Discussion, UGH watter pump gasket in Cadillac Engine Discussion; Ok i just found out today that my water pump gasket is leaking again. This is the 5th time I ...
    quins90lac's Avatar
    quins90lac is offline Cadillac Owners Enthusiast
    Automobile(s): 1990 Cadillac sedan devile
    May 2008
    Peoria IL USA
    35
    616
    Ok i just found out today that my water pump gasket is leaking again. This is the 5th time I have replaced it now. I have tried it with RTV and with out RTV. Also have tried both blue and black RTV also the spray on. So my question no is is there a better gasket out other then felpro? Help me this thing is getting on my last nerve
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,607
    Re: UGH watter pump gasket
    Quote Originally Posted by quins90lac View Post
    How are you installing the water pump? You have to be VERY careful to make sure the gasket lines up PERFECTLY around the area where the 10mm bolts go through to the water inlet. You don't have much wiggle room here, the gasket really has to lay perfectly. That's the easiest area to mess up. This isn't where you are springing leaks, is it?
    Is the timing cover or water pump warped? After 5 times, I'd check everything with a straight edge and make sure all mating surfaces are flat. All it takes is a little overtorquing and everything's bent. Gotta be careful with the sheetmetal materials that make up the timing cover, water pump, and water inlet.
    Otherwise, maybe bring your felpro gasket dealer and ask to see a GM gasket. Compare the two and make sure the felpro gasket is shaped correctly. They should be EXACTLY the same. Sometimes the aftermarkets get them slightly wrong, though it's rare.
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    Yeah, I'm with Drew on this one. Having replaced a good 6 or so WP on 4.x engines, I've never had a go back. Check the WP and make sure it's straight.
    That being said, however, a little RTV should fix just about anything.Do you coat both faces (water pump and block), let tack, and then apply gasket? What's your procedure?
    daniel58 is offline Cadillac Owners Fanatic
    Automobile(s): 58 Coupe Deville, 77 Coupe deville, 90 Deville
    Sep 2009
    183
    All of the above advice is spot on but I would like to add that the FSM torque specs for my 90 Deville were way to high and caused distortion to the front eng cover. The Fel pro tech line (Fel pro is all that is left of aftermarket manufacturers apparently) told me to use generic torque specs and star washers or thread locker on the fasteners. If you have to remove the front cover I would suggest dropping the front (as opposed to the rt side) of the frame to allow more space to work on the front of the eng.
    quins90lac's Avatar
    May 2008
    Peoria IL USA
    35
    616
    Its leaking at the top well back from the pump inlet I have already replaced the pump inlet . Im thinking about drying it off and putting some rtv at the leak sight and letting it dry over night.
    Feb 2009
    Jacksonville, FL
    1,023
    That hardly EVER works. Once it has built pressure to the point it has forced a leak coupled with the fact you really can't clean the coolant off good enough...
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    What about a double gasket with RTV in between?
    Oct 2004
    Oak Creek, WI
    5,607
    Quote Originally Posted by Sevillian273 View Post
    Ugh, I'd be afraid to try something like that...
    Oct 2008
    Palm Bay, FL
    2,024
    Well hell he's done it 4 times already... maybe its time to start thinking outside the box? Maybe the water pump is harder than it looks? Ive never done one on a 4.x.
    Im curious: Do all the bolts come all the way out of the front cover without hitting anything? With my coolant reservoir and battery removed they all appear to be pretty accessible.
    Feb 2009
    Jacksonville, FL
    1,023
    All the bolts come off and there is 2 studs for alignment with nuts on them so you really don't have to hold the thing. It's very straight forward.
    I will say this though, you should always tighten the pump from the center out, not the outside in, as you can buckle the pump possibly causing it to leak....
    quins90lac's Avatar
    May 2008
    Peoria IL USA
    35
    616
    Quote Originally Posted by the recluse View Post
    This is probity what Ive been doing wrong as i cant remember in what order i tightened the bolts and nuts in. Because the only other thing i can think of is that the mounting surfaces aren't smooth enough for the gasket to adhere to
    quins90lac's Avatar
    May 2008
    Peoria IL USA
    35
    616
    UPDATE Found the solution cork gasket no RTV. Also got a new pump but the other was fine checked it out with a strait edge the inside looks fine as well. So i guess i got another pump if i ever need it.
    Feb 2009
    Jacksonville, FL
    1,023
    Thanks for the update, it's always good to see if the advice given is sound or not and/or whether the problem was ever resolved.
  16. #14
    Wendy-J is offline Cadillac Owners Member
    Automobile(s): 1993 Cadillac Sedan DeVille
    Jul 2011
    Somewhere in the ether
    53
    Glad you found the problem. I was going to suggest you buy a sheet of extra thick cork gasket material and cut your own. However, I made gaskets with silicone sealant and minimal torque. You just need the patience to let it dry, then torque it down. For a while there, it was the only pan gasket in use on some of the 1980's GM cars. Remember when they went to a plastic oil pan on the RWD cars?
    Glad you found a solution.
    Wendy.
  17. #15
    cadchris's Avatar
    cadchris is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac 91 Bro-Ham, 91 Yello-dorado
    Sep 2008
    Florida
    46
    245
    A must when doing this pump! Its a small cordless ratchet from Florida Pneumatic #FP-105.
    I told my Snap-On guy about this and he gave it to me at cost for $49 since I told him that Florida Pneumatic had deeply discounted these cordless ratchets but you must buy in bulk or have an account with them.
    Florida Pnuematic was selling these in multiples at a deeply discounted wholesale rate, so he bought 10 and was selling them to local garages for $100. He was happy, and so was I since its a pain to take out those 20+ bolts/nuts!!!!!!! It even has a built in LED.
    http://www.amazon.com/Florida-Pneuma.../dp/B000PUP2X0
    Check e-bay or call Florida Pnumatic for dealers in your area and to see if they are still selling these off cheap in bulk..........maybe put a deal together like I did!
    With regards to the leaking gasket, I'm wondering if his cooling system was overpressurizing? May need a new cap with the correct pressure rating.
    I used Permatex spray gasket adheasive on both sides of the gasket and let it tack up. Permatex #80064
    http://www.permatex.com/products/aut...et_Sealant.htm
    But if this has to come appart, the best gasket remover was from Permatex that has been discontinued per EPA but is still out there: Permatex #80646.
    http://www.permatex.com/products/Ind...et_Remover.htm
    This stuff is very strong and burns the skin. Reminds me of paint stripper which it's probably simialar in formulation.........maybe a spray paint stripper will work also.
  18. Remove Advertisements
