Techheads, answer me this:
Page 1 of 2 12 LastLast
Results 1 to 15 of 21
HT4100 4.1, 4.5, 4.9 Discussion, Techheads, answer me this: in Cadillac Engine Discussion; How is it that I can drive 12 miles in two ignition cycles with both oxygen sensors unplugged and NOT ...
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    How is it that I can drive 12 miles in two ignition cycles with both oxygen sensors unplugged and NOT set any codes??
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,607
    Re: Techheads, answer me this:
    I don't know since I don't have a FSM. What are the conditions that have to be met to set an E013? What do the O2 sensor parameters display as when you are doing this...0.45V or something different? Does the "AUTO" light show while in the onboard diagnostics to show the PCM goes into closed loop or does it stay in open loop?
    I have to ask...what are you trying to do by unplugging them?
    Oct 2008
    Palm Bay, FL
    2,024
    Both sensors read 0.45v and AUTO light stays off just as expected. E013 and E017 set when sensor voltage stays between .30v and .60v for more than 64 seconds, which it did indeed for much longer than that. Both integrators stayed at 128 and both B/L stayed at 118. Everything as expected for having no O2 feedback.
    I wanted to see how it would behave (at operating temp) on the default fuel map while running the overly rich 19# injectors. I didnt notice any difference in power, idle quality, etc although I'm sure mileage suffered quite a bit. One thing I did notice was that the temp stayed between 186 and 190 most of the time which i guess makes sense due to the extra rich fuel. Normally it's 197 to 205. I was blown away to see that no codes were set when I got home.
    The short answer to your question: Shits and giggles.
    Oct 2004
    Oak Creek, WI
    5,607
    Quote Originally Posted by Sevillian273 View Post
    Well, it's still a modified fuel map due to the Block Learn. While the block learn is only ADJUSTED during closed loop (since it's adjustment is based on the integrator which in turn is adjusted based on the oxygen sensors), it's still APPLIED during open loop. If you really wanted to see bone stock fuel map with the 19# injectors, you'd have to reset the PCM, resetting the block learn to 128.
    daniel58 is offline Cadillac Owners Fanatic
    Automobile(s): 58 Coupe Deville, 77 Coupe deville, 90 Deville
    Sep 2009
    183
    I just went round and round with my 90 Deville 4.5 (see dist 180 out post) turned out to be a bad O2 sensor. Never did set ANY codes whatsoever. Also the 19# Venom injectors I had in it are known to run very rich so that did not help things. I ran my car with the O2 sensor removed completely to check for a clogged cat and no codes were set. If you are having problems I would suggest getting an AC Delco O2 sensor and trying that.
    Oct 2008
    Palm Bay, FL
    2,024
    I wasnt having problems... just screwing around asking for trouble After another 20 miles the codes finally did set and whats even weirder is that after getting to work today, somewhere during the ride they became history codes! Who the hell knows.... I'm not going to pursue it.
    I had a sluggish bosch sensor that never set a code either - and while trying to diagnose the problem(one bank ran too rich) I spent a long time and much headache working on the wrong side of the engine because I had ASSumed that the right bank was the one on my right when standing in front of the pulleys. Its funny how such a minor oversight (o2 sensor in your case) can cost you so much work.
    Btw as you may have read http://www.cadillacforums.com/forums...ml#post2344352 19# injectors are too big for your 4.5L
    Sep 2009
    183
    Yes, unfortunately that post stating that 19# injectors are too much for a 4.5 came out 2 months after I installed the 19# Venoms.
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    To answer your original question... OBD I was pathetic.
    The enable criteria for the test probably are not met during your drive cycle. Those sensors were slow to heat up to reach closed loop operation. You are likely pushing closed loop back even further by leaving them unplugged. The computer is probably waiting longe for them to begin reacting. Those are also notorious for cooling off at idle and going back into open loop.
    The short story is the first thing I said above.
    You are running in open loop which will use variations of what the car has been learning in closed loop in the fuel tables so I doubt you'll notice anything other than you are tearing your emissions systems to shreds by doing that...
    Not sure what you are going for here but I doubt that this method is going to show you anything.
    Oct 2004
    Oak Creek, WI
    5,607
    Quote Originally Posted by ewill3rd View Post
    Personally, I've never witnessed this on any of my OBD-1 cars. which is all I've ever owned (still never owned anything newer than '95 ) As an example, my '90 Eldo goes into closed loop before I'm out of my subdivision and will idle all day with decent O2 cross counts...
    Averaging 21mpg around town and a personal best of 27.2 on the highway (I drive it quite conservatively), I'm assuming that the car never plays games like this.
    But interesting nonetheless.
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    My 85 SDV flips between open and closed loop pretty often.
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    I speak mainly of the single wire O2 sensors.
    The multi wire units have built in heaters to get them to closed loop faster.
    I think 95 might have heated O2s.
    The single wires rely on the heat from the exhaust to warm up and that can take some time, and at extended idle they just won't stay hot enough.
    Oct 2008
    Palm Bay, FL
    2,024
    When you say 'one-wire' are you excluding the ground? My 90 has two-wire sensors, one ground and one voltage.
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,969
    there are some single wire sensors out there - usually a purple wire
  16. #14
    ehall's Avatar
    Aug 2007
    Southern Maryland
    1,883
    yeah my 85 is single wire, also my neighbors 93 Caprice is single wire
    3- and 4-wire are self-heating and so they do not keep the car in closed loop (other sensors like coolant temp become the laggard)
  17. #15
    Oct 2004
    Oak Creek, WI
    5,607
    All 4.X's use unheated 02's, including '95's
  18. Remove Advertisements
