allante 4.5! awesome
Results 1 to 8 of 8
HT4100 4.1, 4.5, 4.9 Discussion, allante 4.5! awesome in Cadillac Engine Discussion; well i bought a 1990 allante with the 4.5 and i have to say it is pretty damn good! i ...
    eyekandyboats.inc's Avatar
    eyekandyboats.inc is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 DTS(140K), 2000 ETC(284K), 1990 allante( 80K)
    Mar 2007
    Tottenham, Ontario,Canada
    1,914
    well i bought a 1990 allante with the 4.5 and i have to say it is pretty damn good! i have put over 2500 KM on the car since i got it... so about 2 weeks and all i can say is SWEET average at 21.6 mpg ( 70% in town ) it has some power behind it and the allante handles very well. 86,000 clicks on the car too.
    but one question i would like assistance.
    every so often i have a smell of gas just a bit of it.. i think it might be a leaky fuel rail or something. i have to check it out.. but i wanted to know if this is a common issue on ageing 4.5s or its just a worn item?
    i love my 4.5 so far!
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: allante 4.5! awesome
    Check the fuel pressure regulator; that is a common leak point. Just pull the vacuum hose off it and see if there is gas in there.
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    you shouldn't smell gas in any car
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    EVAP system problem such as improper gas cap or the charcoal canister is filling with gas.
    Mar 2007
    1,914
    gas cap it fine. i was texted when i took my car for emissions test ( which it passed very well i might add on original spark plugs! lol)
    no fuel in FPR either
    where is the charcoal filter
    Oct 2008
    Palm Bay, FL
    2,024
    I dont know about an allante, maybe in one of the front fenderwells. Its pretty big, about the size of coffee can and has numerous vacuum tubes and one electrical connector on top of it. Try the Allante forum. You could also check fuel pressure bleed-down with a gauge to check for a leak.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,607
    Also, I see you are from Canada which nominates the car for corrosion issues. One problem with my Eldo I had was the vent/filler pipe to the fuel tank had a small pinhole in it that caused occasional fumes... Easy as pie to repair if that's the case.
    If the fuel tank was still steel on those, rust at the top of the gas tank is also a possibility.
    You'll just have to sniff around a little on a calm day and try to guestimate the area it's coming from.
    raymondlee is offline Cadillac Owners Member
    Automobile(s): none
    Jan 2011
    Albany, GA
    10
    cn someone explain what an allante is or the difference between this and a 4.9
  11. Remove Advertisements
