leaky rear main oil seal
Results 1 to 5 of 5
HT4100 4.1, 4.5, 4.9 Discussion, leaky rear main oil seal in Cadillac Engine Discussion; Anyone ever used the stuff to help a leaking oil seal? I've seen it at auto parts stores. It supposedly ...
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    Anyone ever used the stuff to help a leaking oil seal? I've seen it at auto parts stores. It supposedly "swells the rubber seals" () My rear main seal is leaking quite a bit, and being a FWD, it's not an option to pull the engine right now. ( had it out twice in the past).
    Next time it's out, a crank and bearing kit will go in it.
    daniel58 is offline Cadillac Owners Fanatic
    Automobile(s): 58 Coupe Deville, 77 Coupe deville, 90 Deville
    Sep 2009
    183
    Re: leaky rear main oil seal
    I have used Lucas products with some success. That was for a steering box that was leaking. Alcohol will swell seals a bit, don't know how it would work in a crankcase however.
    Mar 2009
    mich
    85
    728
    Thanks I'll ask around about the Lucas stuff, or better yet, just try some.
    Today I replaced the ignition switch, and the lock cylinder in the tilt/telescoping steering column. That was interesting. Good thing I have all the manuals........
    Sep 2009
    183
    I feel your pain Steelybill, I had to rebuild the column in my 90 Deville 2 times. The local thieves don't seem to know about the pass key system. Dosn't stop them from doing a lot of damage trying to peel the column attempting to steal the car. Those columns are a piece of work alright, 100 pieices, 4 subsections, lots of fun!
    quins90lac's Avatar
    quins90lac is offline Cadillac Owners Enthusiast
    Automobile(s): 1990 Cadillac sedan devile
    May 2008
    Peoria IL USA
    35
    616
    My rear main seal has been leaking for 2 years now i just have to add a quart ever 1000 miles. As far as Lucas oil stabilizer and stop leak dont bother its a waist of money.
  8. Remove Advertisements
