Persistant Leaking - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
HT4100 4.1, 4.5, 4.9 Discussion, Persistant Leaking in Cadillac Engine Discussion; Cork gaskets only have problems if they aren't installed properly or if they are the cheap ones. You shouldn't have ...
  1. #16
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,424
    Re: Persistant Leaking
    Cork gaskets only have problems if they aren't installed properly or if they are the cheap ones. You shouldn't have to dig through junk yards to get an original gasket you should be able to find one somewhere that's as good as the original or better.
  2. #17
    83CADMAN's Avatar
    83CADMAN is offline Cadillac Owners Fanatic
    Automobile(s): 83 Eldorado, 90 Seville, 94 Concours
    Jun 2009
    Pacific Northwest
    62
    467
    Oh don’t get me wrong; I don’t have to scrounge the junkyard for a used gasket. My logic is simply this. For $2.00 entry I was able to simulate a transmission pan removal, check out the insides, and while I was at it a reusable OEM gasket would translate into a $10.00 savings. Also I spotted a pair of new front drive axles on the same car. Those puppies run 80 bucks each for remanuf units. My cost; a couple of hours labor to pull and $40.00 for the pair.
  3. #18
    83CADMAN's Avatar
    Jun 2009
    Pacific Northwest
    62
    467
    Hey recluse! What parts are you looking for?
  4. #19
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    Looking for interior parts, mostly; but it has to be the Oxblood interior...
  5. #20
    83CADMAN's Avatar
    Jun 2009
    Pacific Northwest
    62
    467
    When I dropped the pan this is what I found (see pic).
    What is that dk gray matter streaking the bottom?
    The unit had been flushed a couple yrs ago and the shop obviously reused the old gasket.
  6. #21
    83CADMAN's Avatar
    Jun 2009
    Pacific Northwest
    62
    467
    Quote Originally Posted by the recluse View Post
    I was at the yard today, I scored a pair of OEM axles, slighty used from the looks of them. The rubber boots were heaver rubber also.
    While I was out there I walked the yard and took a look for oxblood interior Eldo's. Didn't find any. There was a Seville through.
  7. #22
    83CADMAN's Avatar
    Jun 2009
    Pacific Northwest
    62
    467
    Quote Originally Posted by 83CADMAN View Post
    No one has ever seen this kind of sludge in the transmission Fluid? Come on!
  8. #23
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Sorry, missed the updates on this thread. Am I one of the only ones left who regularly check this section of the boards?
    The black "sludge" in the bottom of the pan is clutch material. It's typical to see some in the bottom of the pan; there will always be some as slipping clutches is what makes a smooth shifting trans.
    That said, with the amount in your pictures, I'd say it's been a LONG time since the pan has been dropped. You say you got it FLUSHED a few years ago, but was the pan dropped for a cleaning and new filter?
    Black clutch material is fine...what you don't want is any silvery color or metal flake mixed in there or metal chunks on the pan magnet, which could be representative of some severe wear and near-future problems. The magnet is there for really fine metallic material from the steel clutch plates and such, but there shouldn't be anything excessive. Anything stuck to the magnet is NOT clutch material as it's not ferrous nor magnetic.
  9. #24
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Quote Originally Posted by drewsdeville View Post
    Yup.
    Sometimes when I visit this section I hear crickets chirping.
    I usually skip threads about cads earlier than '88.
    I've never seen so much clutch material in a pan like that... Is there a magnet in there somewhere?
  10. #25
    83CADMAN's Avatar
    Jun 2009
    Pacific Northwest
    62
    467
    Hey Thanks Guy's for the reply.
    I really do not think the shop that performed the flush dropped the pan completly, just enough to change the filter, plus they reused the old gasket, which leaked.
    They were supposed to do a chasis lube as well. Right!!
    Every zerk under there took at least 5 pumps of grease the other day when I did it.
    If you want it done right! Right?
    Good to know about what should be and what shouldnt be in the bottom of that pan.
    Just some clutch sludge. Cool! I didnt find any metal at all in the fluid or metalic residue in the bottom of the pan. Also I didnt see any magnet in the pan when I droped it. Is there supposed to be one? I dropped a couple of pans at the salvage yard and saw no magnets there either.
  11. #26
    Feb 2009
    Jacksonville, FL
    1,023
    Thanks for looking and sorry I couldn't/didn't get back to you earlier, I've been remodeling a bathroom while my wife was out of town. I didn't think you'd find anything, but thanks anyway.
    I'm with the other two on this one, that pan may have been dropped and the filter changed, but that tranny was not flushed. I find quite a few shops throw that phrase around but rarely do a full flush on a flushing machine; probably because it takes about 30 quarts to do it right.
    And yes, there should have been a magnet in the bottom of the pan somewhere, mine was a small, rectangular, flat, magnet right in the middle of the pan.
  12. #27
    83CADMAN's Avatar
    Jun 2009
    Pacific Northwest
    62
    467
    No problim Recluse, I was cruzing the yard anyway. Bet your wife was happy when she returned to a new BR.
    The magnet, hemmmm, I've allready put everything back together, so do I need to drain and drop the pan just to place magnet, or since I found no metalic evidence in the old fluid can I not wory about it?
  13. #28
    Feb 2009
    Jacksonville, FL
    1,023
    With as big an overhaul as I was doing to this bathroom, no it wasn't quite done when she got back, but she'll love it in the next week...
    No I wouldn't drop the pan for a magnet at this point, but if you ever have to get in there in the future I would.
  14. #29
    83CADMAN's Avatar
    Jun 2009
    Pacific Northwest
    62
    467
    By the way the leak is no more.
  15. Remove Advertisements
