Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > HT4100 4.1, 4.5, 4.9
HT4100 4.1, 4.5, 4.9 This forum is to discuss the newer aluminum block Cadillac engines.
Cadillac Forums: Rough Idle
Old 09-07-04, 06:26 PM
View caddy john's Photo Album
Casino Cash: $250
Rough Idle
I have a 91 Sedan Deville and it idles great until I turn on the headlights, then it becomes very rough. It has a knocking sound, I have replaced the ISC snd I think I have set it up OK. I have replace the Oxygen sensor, cleaned the throttle body and the egr ports. I am at a loss, no codes. Please Help !
  #2 (permalink)
Old 09-07-04, 08:28 PM
100 100 is offline
Cadillac Owners Enthusiast
Cadillac(s): 1995 Sedan De Ville (4.9 L)
View 100's Photo Album
Casino Cash: $260
Re: Rough Idle
So, the engine idles fine (and I suppose the car runs fine), unless you turn on the headlight, is this correct?
To me, it sounds an electrical problem, or to be specific, bad ground. If I were you, I would make sure the ground is fine, especially one for the computer or the ground wire from the battery to the body.
Good luck.
  #3 (permalink)
Old 09-07-04, 11:42 PM
Stoneage_Caddy's Avatar
Cadillac Owners 10000+ Posts
Cadillac(s): 94 Deville 4.9 (Gladys),2006 H-D 883-R (Midnight Rider)
View Stoneage_Caddy's Photo Album
Casino Cash: $5520
Re: Rough Idle
how many volts are at the alternator(or battery) with the headlamps on ?
if its not a mid 12 to low 13 volts they sometimes will run rough , not positive on why but weak volts/amps sometime cause rough running
  #4 (permalink)
Old 09-08-04, 01:52 AM
CadiJeff's Avatar
Cadillac(s): 1981 CoupeDeville, 2 1990 Eldorados, 1994ETC ,1992STS
View CadiJeff's Photo Album
Casino Cash: $435
Re: Rough Idle
I would recomend checking the batt and alternator sounds like a low volt situation to me.
  #5 (permalink)
Old 09-08-04, 11:11 AM
Casino Cash: $250
Re: Rough Idle
I just checked the ground on the batt. and cleaned off everything. I checked the voltage and when at idle with lights on I have 12.65 volts, with lights off I have 12.82 volts. When the engine is running rough I give it a little gas and it quites running rough, I knocks and pings when it really gets rough. I am going to check the computer ground after work tonight. Ihope this works, if anyone has any other clues please let me know. Thanks from Florida
  #6 (permalink)
Old 09-08-04, 11:28 AM
maclugie's Avatar
View maclugie's Photo Album
Casino Cash: $250
Re: Rough Idle
I don't post too often, however; I've been having the same battle with my car. It is a well-maintained 1993 Seville with 71500 miles and the 4.9 engine. I too have changed the ISC motor, and performed the idle re-learn procedure and cleaned the TB. Still no joy on the rough idle under load condition. Interestingly, the car wasn't throwing any codes - - until now I am getting PO91 - PRNDL problem. I have been doing a little research and was thinking maybe the computer "brain" doesn't know what gear the car is in. Could this cause a problem with the idle when the car is in gear and a load is placed on the engine; i.e., lights, a/c? Would this cause a problem with the car going into looped and closed looped operation? I'm not a mechanic but I do like fixing cars myself, if possible. Does anyone know if I'm going down the right path here?
  #7 (permalink)
Old 09-09-04, 12:15 AM
Casino Cash: $5520
Re: Rough Idle
Mine throws the po91 every once and awhile , i have no idle problems
For you , you need to check the tightness of the swtich on the tranny int he area where the shift cable connects . the 3 bolts sometimes come loose causeing slop in that switch/sensor confuseing the car ....
on the other car , voltage looks fine to me , but check your grounds , ive also heard for a couple people running an extra ground wire helps
boath cars :when was the last time the fuel filter was changed ?
  #8 (permalink)
Old 09-09-04, 08:42 AM
maclugie's Avatar
Casino Cash: $250
Re: Rough Idle
I changed the fuel filter last year - 15000 miles ago.
  #9 (permalink)
Old 09-09-04, 09:42 AM
Casino Cash: $250
Re: Rough Idle
I changed my fuel filter 1100 miles ago, I am going to run another ground today and also make sure the gound on the computer is ok. Will let you know later today, I hope it works. Thanks caddy john
  #10 (permalink)
Old 09-09-04, 12:47 PM
Casino Cash: $250
Re: Rough Idle
I checked the computer ground it checked out good, I then removed the power to alternator and cleaned it up, then removed both cable connections on batt. the pos. terminal was really cruddy. I reset my codes on computer and tried it out. Darn it still started running rough after all that. So when it started running bad this time I put it in Park, it smoothed out. I then put it back in drive, it ran smooth for about 1 min. the it became rough again, so I tried park again it got smooth. I then put it back in drive, it idled smooth, I let it idle for 10 min. It ran smooth all that time, I hope it is fixed. I will let you know in a few days. Still do not know what fixed it, but it is great now. Thank everyone for the help and if you know what helped let me know.
  #11 (permalink)
Old 09-09-04, 08:18 PM
Casino Cash: $250
Re: Rough Idle
Well just got back from a drive of 150 miles, bad news. It idled great going over, but when I stopped to get something to eat when I started to idle rough, I tried putting it in park but no good it keep getting rougher. I gave it some gas and tried again, not good. After about 10 miles it started doing great again. I just do not understand what is going on. Please help, Thanks caddy john
  #12 (permalink)
Old 09-11-04, 10:03 AM
Casino Cash: $250
Re: Rough Idle
Still having problems with rough idle when car is warmed up, when it starts to become rough it knocks and makes bad noises. I give it some gas and it will smooth out, it only seems to do it when it is driveat highway speeds and then comes to a stop and beins to idle. It takes about 15 sec. after it is at an idle then it begins. I am at a loss any help is needed. Thanks for Florida
  #13 (permalink)
Old 09-11-04, 12:41 PM
Casino Cash: $5520
Re: Rough Idle
does it still only do it with the headlamps on ?
  #14 (permalink)
Old 09-11-04, 04:09 PM
100 100 is offline
Casino Cash: $260
Re: Rough Idle
It happens when:
all these 3 conditions are met,
(1) in "D"
(2) but idle (no throttle)
(3) the headlight is on.
Am I right?
  #15 (permalink)
Old 09-12-04, 09:35 AM
Casino Cash: $250
Re: Rough Idle
It does not make any difference now if the lights are on or off, when it begins to idle rough I put in in park and it continues to get rougher. I give it some gas and it stays rough for about 1-2 seconds, smooths out then I put it back in drive and it usually smoothes out.
Tags: ,
idle, rough
