spark plugs
Results 1 to 11 of 11
HT4100 4.1, 4.5, 4.9 Discussion, spark plugs in Cadillac Engine Discussion; Hi Guys, What is the spark plug gap in mm for an 83 4100? Also I'm about to change the ...
    Ruud is offline Cadillac Owners Fanatic
    Automobile(s): 1983 Coupe Deville
    Jul 2009
    Loch Lomond, Scotland
    110
    spark plugs
    Hi Guys,
    Also I'm about to change the oil...is it still 'safe' to use 15w40 diesel oil?
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    Re: spark plugs
    15w40! WOW! I thought the spec was 5w30? I wouldn't use that heavy an oil in the wintertime...
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    Re: spark plugs
    I looked through my manuals, and couldn't find the plug gap, but it's usually in the owners manual.
    I've been using Valvoline racing oil in my 4.1 (VR-1) I don't want to replace the cam again, so with the ZDDP in the racing oil, it may last a while.
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Re: spark plugs
    HEI can run up to .060"
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: spark plugs
    Quote Originally Posted by Sevillian273 View Post
    Theoretically. I try to tighten it up a little if I don't have to bend the side electrode too much. Hi PO Chevys always ran .045"; somebody figured out that they couldn't handle .060"
    Jul 2009
    110
    Re: spark plugs
    is that .60 mm?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,877
    Re: spark plugs
    .060 inch. Sixty thousandths.
    For oils which have an added anti-scuff package (ZDDP) in your correct viscosity range do some research on Chevron DELO, Pennzoil LongLife, and Shell Rotella fleet and marine oils. They are available in 10W-30 and 10W-40 weights and they have about the same anti-wear package as the pre-"starburst" oils.
    15W-40 is really too heavy for a small engine.
    Oct 2008
    Palm Bay, FL
    2,024
    Re: spark plugs
    IMO, I would only use 15w in a 150K mi+ motor with the oil light coming on at idle(low pressure). Not a fix by any means but cheaper than a rebuild. That situation probably doesnt apply here so I'd go with the recommended weight.
    $0.02
    Oct 2008
    Palm Bay, FL
    2,024
    Re: spark plugs
    Quote Originally Posted by cadillac_al View Post
    Makes sense. I run mine at .060 with a MSD 6A box with no problems. The tiniest turn of the crank and she roars to life
    Mar 2009
    mich
    85
    728
    Re: spark plugs
    .060 thousands is close to 1.55 MM For .045 thousands you could use 1.15 MM.
    The .060 inch plug gap presents more potential for the plug wire insulation to deal with, which may be a problem for old wires.
    1copenhagen is offline Cadillac Owners Member
    Automobile(s): 2005 DeVille
    Jul 2010
    Missouri
    53
    25
    Re: spark plugs
    Quote Originally Posted by steelybill View Post
    .060 is what my 85 Eldo calls for and steelybill I think you are right after I changed my plugs I have a miss under heavy acceleration but my car still has the the 1985 wires and cap and rotor
  14. Remove Advertisements
