93 deville turn signal problems
Results 1 to 8 of 8
HT4100 4.1, 4.5, 4.9 Discussion, 93 deville turn signal problems in Cadillac Engine Discussion; Hey everone how are you i got a 93 deville 4.9 with 105k miles on it just last week when ...
    mike93 is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Cadillac sedan deville
    Sep 2009
    Media, Pennsylvania
    25
    281
    Hey everone how are you i got a 93 deville 4.9 with 105k miles on it just last week when i put my turn signal on when i turn left the arrow on the dash and the front and rear lights just stay solid when i put the signal to the right everything blinks put a new flasher not that put new rear signal bulbs not that and checked the fuse is good and there is no turn signal relay please help what can it be thanks
    mike
    revdowrong's Avatar
    revdowrong is offline Cadillac Owners Fanatic
    Automobile(s): 91 sedan deville
    Jan 2007
    san antonio, tx
    33
    341
    Re: 93 deville turn signal problems
    Its the actual turn signal switch inside of the steering wheel that's causing the problem.
    Sep 2009
    Media, Pennsylvania
    25
    281
    oh have u had that problem and if you did how much is the switch i will do it myself thanks
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    You mentioned the rear bulbs but what about the front? The front and rear bulbs are wired in parallel. When any of the bulbs on the circuit go out, the circuits resistance goes up, current draw goes down and the relay no longer works correctly.
    The bulbs must all be working with good connection to their sockets (connections in the rear can be a concern) and the bulb values must be correct
    Sep 2009
    Media, Pennsylvania
    25
    281
    yeah i forgot to say that i changed the front bulbs also just started today now with the turn signal not even on the arrow on the dash just stays on with the signals off
    Feb 2003
    california
    69
    6,663
    The best way to diagnose this is to turn on the 4 way emergency flashers and walk around the car looking for a failed bulb. If all seem ok, then I would suspect the turn signal switch. A flasher light staying on, turn signals off means a poor ground in a bulb socket. This car was famous for corroded rusted sockets.
    daniel58 is offline Cadillac Owners Fanatic
    Automobile(s): 58 Coupe Deville, 77 Coupe deville, 90 Deville
    Sep 2009
    183
    If I remember correctly changing that turn signal switch is not an easy job. You should get a Factory Service Manual and study a bit before attempting this job. You will need a steering wheel puller, snap ring pliers etc. Also you have to be very careful with the air bag assy, if it blows up you could get hurt.
    behind-bars is offline Cadillac Owners Connoisseur
    Automobile(s): 93 Sedan Deville 4.9L
    Sep 2005
    Texas
    1,005
    Check your grounds under the hood, There are some wires bolted to the side fender that could be bad. If I leave my wires unbolted the turn signal light on the dash stays solid. It is a small black wire with a little hex nut holding it to the side fender under the hood, My old 93 deville had something broken in the steering column, or in the stalk and the cornering light stayed on unless you lifted the turn signal stalk by hand slightly, If the bulb works I would look into other causes.
  11. Remove Advertisements
