4.5 in an Isuzu Trooper
Results 1 to 6 of 6
HT4100 4.1, 4.5, 4.9 Discussion, 4.5 in an Isuzu Trooper in Cadillac Engine Discussion; I'd like to see his motor mounts http://www.cardomain.com/ride/2046320/3...
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    noahsdad's Avatar
    noahsdad is offline Cadillac Owners Connoisseur
    Automobile(s): '87 SDV
    Jun 2005
    Michigan
    57
    1,296
    Re: 4.5 in an Isuzu Trooper
    That's just crazy. Wonder how he gets around all the ECM controlled stuff (tps, o2 sensors, injectors, etc?)
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Thats pretty cool! I've never seen a 4.5 in anything else besides a fiero. He must have chose it to save weight... probably not the most ideal engine for his application.
    ehall's Avatar
    Aug 2007
    Southern Maryland
    1,883
    The torque curve on these is pretty good, plus the weight is a factor. Having said that I wouldn't do it, since the amount of custom fab work required is pretty high compared to something like a Chevy 350. The benefit just wouldn't be worth the development effort.
    As for ECM work I ass-u-me he used the one from the donor, but then the next question is if he also used the BCM, and what did he do about all the other stuff (gauges etc). It's a trail boat so he probably skipped on all that. Or maybe he used a stock GM throttle body and FI controller, those are widely available but then issues with ISC management, etc., and its not a 350, so ... I dunno.
    Must have been a free car.
    ehall's Avatar
    Aug 2007
    Southern Maryland
    1,883
    I was searching to see if I could find more info and found another one...
    http://myweb.cableone.net/bcanderson...c/cadillac.htm
    Discussion board posts say change the TBI and injectors, and the Trooper computer works. Early gen Troopers apparently used GM TBI engines same as the S-10 Blazer. Dunno how they get around the ignition.
    Will's Fiero is offline Cadillac Owners Member
    Automobile(s): 1987 Pontiac Fiero GT with built flat-tappet Northstar
    Jan 2006
    20
    7730 computer from a multitude of GM applications, including '90-'92 Transmarobirds can be retuned to run a PFI 4.5/4.9, especially if using a throttle body from a TPI or LT1 engine.
    The TBI engines can be run by almost any OBDI computer GM made.
  9. Remove Advertisements
