84 eldo. antena
Results 1 to 5 of 5
HT4100 4.1, 4.5, 4.9 Discussion, 84 eldo. antena in Cadillac Engine Discussion; hi, recently got back from a 3000 mi trip with my 84 eldo. conv. mostly went well the 4100 purred ...
    DNE
    DNE is offline Cadillac Owners Member
    Automobile(s): 84 eldo. cov.
    Aug 2009
    61
    16
    84 eldo. antena
    hi,
    mostly went well the 4100 purred right along fair amount of mountain driveing(near mpls, to boise) ave. about 20 mpg. trouble was a bird took out the antenna, the top sec conected to plastic part that winds up is ok the 2 bottom sec are kinked and need to be replaced. does any one know were I could find them. ckecked with gm, and rock auto. no luck
    thanks for any help
    DNE
    pocketpared is offline Cadillac Owners Fanatic
    Automobile(s): 1992 Eldorado
    May 2009
    200
    Re: 84 eldo. antena
    Look into antennamastsrus.com I got them from this site. Very well spoken of and I can add to that.
    DNE
    Aug 2009
    61
    16
    Re: 84 eldo. antena
    thanks, will give antennamastersrus a try
    DNE
    83CADMAN's Avatar
    83CADMAN is offline Cadillac Owners Fanatic
    Automobile(s): 83 Eldorado, 90 Seville, 94 Concours
    Jun 2009
    Pacific Northwest
    62
    467
    Re: 84 eldo. antena
    I just replaced the whole power antenna unit on my 83 with a used one I located at a local U-PULL yard. Simply mark the passengers side hood hinge (at hood and fender) and remove, be careful none of the fender mount shims drop down into the fender cavity and are returned for proper hood alignment. Note: A fully retracted antenna indicates a good chance the unit is operational. Good luck.
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    Re: 84 eldo. antena
    And put a thick blanket on the wiper cowl so as to not damage it and rest the hood there and put a pair of vise grips on the chrome shaft of the left hood gas support to hold the hood up. I even use a broom stick to help support the hood on the passenger side. The antenna assembly must be rotated just so to get it out of the fender and by the way cut off the extended mast before removal. Replace the whole assembly.
  8. Remove Advertisements
