replacing a 4.1
Results 1 to 9 of 9
HT4100 4.1, 4.5, 4.9 Discussion, replacing a 4.1 in Cadillac Engine Discussion; Has anyone replaced a 4.1 with a 4.9, and used the TBI system in the car, as opposed to the ...
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    replacing a 4.1
    Has anyone replaced a 4.1 with a 4.9, and used the TBI system in the car, as opposed to the multi-injector system which is used on the usual 4.9??
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    Re: replacing a 4.1
    Basically you need to keep your existing intake manifold and then figure out a way to trick the computer so that fuel delivery matches the larger displacement
    http://www.cadillacforums.com/forums...m-bearing.html
    http://www.cadillacforums.com/forums...66-post10.html
    I think Illuminati has done this swap too, not sure
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,607
    Re: replacing a 4.1
    Would you need to trick it?
    The system should work the same. The O2 sensor data will determine the a/f mixture and the ecm will compensate accordingly by adjusting the integrator (injector pulse width). For a larger displacement, the O2 sensor data will show a lean condition from baseline and the ecm will increase the integrator, lengthening the injector pulse until it makes the O2 sensor happy.
    The system is VERY forgiving as it has to be able to adapt to extreme conditions. Personally, I think it would work just fine without any "tricking"
    ehall's Avatar
    Aug 2007
    Southern Maryland
    1,883
    Re: replacing a 4.1
    The basic principle of FI engines is that the driver controls air flow (throttle blades), then the computer looks at air temperature and pressure to derive density, applies that value against known displacement to determine combustible air in the manifold, and finally injects the appropriate amount of fuel. As I understand it, the O2 just modifies the curve and doesn't override the calculations. Of course when the displacement goes up, the air volume changes, so the calculations are thrown out of whack. In the jeep world the common fix for this problem (strokers are pretty common) is to tweak the MAP sensor to trick the computer's air density calculations. Every thread I've read about the subject here talked about using an adjustable FPR to boost the fuel quantity for each pulse. I suppose either would work, some other things might too.
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Re: replacing a 4.1
    How's it gonna run the engine before closed loop when it starts using the o2's feedback? A smaller FI system on a bigger engine will run lean until the o2 sensors 'wake up' and tell the computer something is wrong. You might try bigger injectors to compensate and then rely on the system to dial the fuel back after closed loop. Just an idea. It wont be 100% plug and play....
    Oct 2004
    Oak Creek, WI
    5,607
    Re: replacing a 4.1
    I assumed the learned long term fuel trim that is stored would take care of warm up. While short term only takes care of closed loop operation, like you mention, long term takes effect in both open and closed loop. Of course, then it would run horribly whenever the battery is disconnented...
    But yes, ehalls comment makes sense. If it wouldn't work, I'd head over to the fiero guys and have someone build you a custom PROM rather than messing around modifying sensors.
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    Re: replacing a 4.1
    I would use the 4.5 not the 4.9. 4 tenths of a liter would not confuse the fuel delivery system.
    noahsdad's Avatar
    noahsdad is offline Cadillac Owners Connoisseur
    Automobile(s): '87 SDV
    Jun 2005
    Michigan
    57
    1,296
    Re: replacing a 4.1
    Agree with carnut. The 4.5 swap is much less finicky. Not quite plug and play, but close. Look up some old posts from Illumnati from about 3-4 years ago (or PM him if he's still around). He did this swap a number of times, and had it down to a science.
    themadwacker1 is offline Cadillac Owners Fanatic
    Feb 2007
    265
    Re: replacing a 4.1
    Quote Originally Posted by steelybill View Post
    I did this same swap 2 years ago with my 1986 4.1 Sedan Deville but with a 4.5 TBI. All the info with pics is there & should help. If you need more info I can help, just post or PM me your questions.
    http://www.cadillacforums.com/forums...4-1-4-5-a.html
    P.S. It's a big job so be ready to work..
  12. Remove Advertisements
