Where do I connect Tach - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 42 of 42
HT4100 4.1, 4.5, 4.9 Discussion, Where do I connect Tach in Cadillac Engine Discussion; Repeated the process this afternoon, except this time not using a jumper harness and the green test connector by the ...
  1. #31
    83CADMAN's Avatar
    83CADMAN is offline Cadillac Owners Fanatic
    Automobile(s): 83 Eldorado, 90 Seville, 94 Concours
    Jun 2009
    Pacific Northwest
    62
    467
    Re: Where do I connect Tach
    Repeated the process this afternoon, except this time not using a jumper harness and the green test connector by the distributor disconnected...
    I cant get that damn plunger to retract!!!!
    Still no codes. Sooooo Close. What am I doing wrong??? Do I need to unplug the TPS before manualy performing the ISC plunger retraction?
  2. #32
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    No, are you lifting up on the throttle with one hand while depressing the plunger with the other? Thats the proper way. If you dont open the throttle slightly the isc will not retract.
  3. #33
    83CADMAN's Avatar
    Jun 2009
    Pacific Northwest
    62
    467
    The last time I tried that approch, Still couldnt get it to move.
  5. #34
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,607
    Quote Originally Posted by 83CADMAN View Post
    Then the "closed throttle" switch inside the ISC is dirty/broken. This also explains the high idle.
  6. #35
    83CADMAN's Avatar
    Jun 2009
    Pacific Northwest
    62
    467
    Quote Originally Posted by drewsdeville View Post
    That explains why the plunger would'nt retract. The jumper wire method must bypass the "closed throttle switch" and just runs the motor backwards. The fact that I went thru 2 junkyard units and both were bad is not surprising, and at $3.00 each I’ll go back again. Price new at NAPA, $130.00. They also list a plunger repair kit for $30.00. I think I’ll tear into one and see what’s what.
    What a relief, everything else is OK then. I wonder how many of these cars wind up in the bone yard because of a bad ISC. I’ve been looking and I see a lot of new parts on some, but the ISC’s all appear rather dated.
    I'll get the ISC repaired and post results. Thanks
  7. #36
    83CADMAN's Avatar
    Jun 2009
    Pacific Northwest
    62
    467
    I disassembled the original ISC I had previously removed. I found no mechanical issues within the ISC, ie: broken gear, burnt/corroded contacts etc. Running a continuity test indicated the switch contacts were OK and that the switch functioned properly.
    I repeated the test on the junkyard ISC and it also tested OK.
    The repair kit I found consist of just the plunger shaft w/ gear and rubber boot.
  8. #37
    83CADMAN's Avatar
    Jun 2009
    Pacific Northwest
    62
    467
    What if…
    Either the “Manifold Air Temperature Sensor (MAT)”
    Or the “Coolant Temperature Sensor (CTS)”…
    Are weak and the ECM is responding to cold start, hence the fast idle. If the ISC were receiving cold start data, wouldn’t it want to extend and hold the ISC plunger at fast idle?
    Maybe that’s why I couldn’t get it to retract?
    I think the OBD would display a code if the circuit or sensor failed, but what about a weak sensor condition. Wrong temp data to the ECM right.
    The TPS “0 volt” setting can be set either hot or cold, as long as the throttle lever is not impeded and allowed to close completely.
  9. #38
    83CADMAN's Avatar
    Jun 2009
    Pacific Northwest
    62
    467
    I snaped a couple of pictures of the disassembled ISC If any one is intrested.
  10. #39
    83CADMAN's Avatar
    Jun 2009
    Pacific Northwest
    62
    467
    I took the multi-meter to the temp sensors today after I reassembled and installed the original ISC unit. Cold they tested OK, so I figured in order to get the maximum reading out of the manifold air temp I should install the air cleaner, connect all the hoses including the heat riser.
    Started up and ran it for about five min or so then shut it down. I pulled the air cleaner to get at the sensors, and they tested OK…..WTF?
    Well I hooked up the tach, and multi-meter to the TPS and fired it up again while it was still hot.
    Guess what? This time when I tried to press the ISC plunger IT MOVED!!!!!!!HOT DAMN!!!!!!
    WAS IT THE AIR TEMP ALL ALONG THAT WAS KEEPING IT IN CLOSED LOOP?
    In my previous attempts I had removed the air cleaner prior to warm-up, I merely felt the top radiator hose, when it was hot so I knew the thermostat had opened.
  11. #40
    Feb 2003
    california
    69
    6,689
    You mean open loop (prior to oxy sensor being activated) You could be right about the air cleaner, I've always waited till engine temp was about 90 cel. before I removed the filter assembly. SO------- Is it fixed?
  12. #41
    83CADMAN's Avatar
    Jun 2009
    Pacific Northwest
    62
    467
    Wild huh. Every procedure I read involving warm-up noted removal of air cleaner prior.?
    Well it worked; I was able to get the ISC retracted and the TPS adjusted. Idles smooth now. I am experiencing a chugging effect upon acceleration through. I’m thinking weak coil pack maybe.
    Taking a little break from it right now. I need to replace a rear air strut on my 91 Seville, going to do the front brake pads while I’m at it. So I got to move the Eldo out of the shop to make room.
  13. #42
    83CADMAN's Avatar
    Jun 2009
    Pacific Northwest
    62
    467
    I was able to replace the coil before I had to move the car out of the shop. No difference. I also changed out the EGR valve. I think next I’ll go through the spark plugs again and check the cable routing.
  14. Remove Advertisements
