Ht4100 question
Results 1 to 5 of 5
HT4100 4.1, 4.5, 4.9 Discussion, Ht4100 question in Cadillac Engine Discussion; Is there a difference in the HT4100 engine in a 1985 Fleetwood Coupe full size RWD to a 1985 full ...
    SCU187 is offline Cadillac Owners Member
    Automobile(s): 85 Fleetwood Coupe RWD & 78 Phaeton Coupe
    Oct 2009
    21
    Ht4100 question
    Is there a difference in the HT4100 engine in a 1985 Fleetwood Coupe full size RWD to a 1985 full size Eldorado. Both with the same VIN code (8). What I wanted to do is use a 4100 engine in an Eldorado to replace my blown 4100 in my Fleetwood coupe.
    cadi509's Avatar
    cadi509 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS V Tango int
    Jan 2010
    Yakima, Wa
    27
    2,337
    Re: Ht4100 question
    As long as their both the rwd engine I would think you'd be fine, but you should post this down in the engine section you'll get more and better responses
    68
    81,748
    Re: Ht4100 question
    Moved
  5. #4
    chp350 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 srx 1997 etc 1993 allante 1970 coupe deville 1979 t/a
    Oct 2006
    112
    Re: Ht4100 question
    eldorado"s (fwd) use a different oil pan and oil pick up tube...use the rwd parts, oil pan,mounts,and exhaust manifolds and it will work
  6. #5
    Oct 2009
    21
    Re: Ht4100 question
    Thanks everyone.......
  7. Remove Advertisements
