93 deville running great
Results 1 to 8 of 8
HT4100 4.1, 4.5, 4.9 Discussion, 93 deville running great in Cadillac Engine Discussion; Hey everyone I have a 1993 cadillac sedan deville that has 105,000 miles on it it's been running great the ...
    mike93 is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Cadillac sedan deville
    Sep 2009
    Media, Pennsylvania
    26
    281
    Hey everyone I have a 1993 cadillac sedan deville that has 105,000 miles on it it's been running great the only thing is that 10 months ago i had the trans rebuilt and now the torque converter locks up way to early at like 27MPH the car shifts great and everything just the torque converter locks up way to early and no codes what could it be thanks everyone!
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Re: 93 deville running great
    I'm not sure if 27mph lockup is abnormal or not, as my '90 Eldo locks up around the same speed if I'm driving it VERY easy. Anyway...
    TCC lockup is usually determined by coolant temp, vehicle speed, brake switch (closed for lockup), transmission line pressure and TPS angle. Coolant temp and vehicle speed requirements are programmed into the PCM. A faulty brake switch could only PREVENT lockup, not initiate it early. Same goes for inadequate line pressure. The TPS or faulty speed info to the PCM are the only adjustable variable here.
    Be sure that the TPS is correctly adjusted and working properly. Make sure that your speedo is correct.
    Sep 2009
    Media, Pennsylvania
    26
    281
    I don't think it's normal everyone tells me it's supposed to lockup around 42 MPH but i still have 2 months left on my warranty so ill bring it back to aamco monday and tell them about it
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    Quote Originally Posted by mike93 View Post
    ...ill bring it back to aamco monday and tell them about it
    Oh God, there's your problem I hate AAMCO
    Don't let them fool around till the warranty expires (they will try). They buy cheap Chinese built torque converters that are almost NEVER machined right, I had one in a Plymouth tranny they built that blew the replacement tranny 11 months into the warranty and had to sue them for recovery. When it was pulled apart my trans tech showed me the hub was .033 out of round! Told me AAMCO has a truck load of return (faulty) torque converters for every 2 truck loads that come in.
    Be admit and act fast.
    Sep 2009
    Media, Pennsylvania
    26
    281
    yeah i know the thing shifts fine and everything just the torque converter locks up to early i hear that if that happens to much it will burn up the forth clutches because of the trans locking and unlocking creating so much heat
    hcaddy95's Avatar
    hcaddy95 is offline Cadillac Owners Fanatic
    Automobile(s): 1995,Cadillac Deville,HT 4900
    Aug 2008
    Milwaukee,Wi
    31
    112
    you still haven't taken it back to them yet its been awhile youv'e been having problems with your deville for sometime now Goodluck
    oh you can look up your tps reading in your Driver Information Display also
    Sep 2009
    Media, Pennsylvania
    26
    281
    Ive bought it to them about 5 times seriously called BBB called AAMCO consumer affairs and nothing gets done i keep fighting with them but tell me it's normal when it not and in august the warranty expires only one more month left im gonna make them fix it somehow i will find a way!
    Feb 2009
    Jacksonville, FL
    1,023
    Get an independent second opinion from at least two other shops (not AAMCO) and then go back to AAMCO with the results. It may be nothing, but I seriously doubt it. GM designs a tranny that runs forever and AAMCO can't rebuild it to last a year?
  11. Remove Advertisements
