4.9 Distributor / Timing question
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
HT4100 4.1, 4.5, 4.9 Discussion, 4.9 Distributor / Timing question in Cadillac Engine Discussion; Alright I've been tinkering with the timing on my 4.9. I don't have a timing light and am kinda doing ...
    Cream_Devil_91's Avatar
    Cream_Devil_91 is offline Cadillac Owners Member
    Automobile(s): '91 Sedan deVille
    May 2009
    903
    28
    Alright I've been tinkering with the timing on my 4.9. I don't have a timing light and am kinda doing it the "old-school" way supposedly. I've advanced it to the point where it doesn't want to turn over easily when starting, and have backed it back a little bit from there.
    My question I can't seem to find an answer to is just how much of a turn on the distributor corresponds to a degree or two in the timing? I think I've been moving it from one extreme to the other with turns of about 1/2 to 1 inch. Can someone give me some sort of idea how much I should be moving the distributor for a 1 or 2 degree change? I ran out of daylight and am going to work on it tomorrow evening.
    Symptoms have been when too retarded: Louder, droning exhaust, loss of power, hot exhaust temps
    Symptoms when too advanced: Starter kickback, acts like it doesn't wanna turn over, pinging
    Can't seem to find a happy medium Really don't wanna buy a 50 dollar timing light for a one time adjustment, hoping I can get it close enough by trial and error. Tomorrow I will try adjusting in smaller increments, but would like an idea of how small we're talking here.
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Re: 4.9 Distributor / Timing question
    1/2" sounds like alot but I've never actually measured.... Each degree is a very small turn of the distributor. I find it hard to move it one degree at a time and usually have to go back and forth a few times to get it where I want so that's how small of a turn each degree is. I would turn it counter clockwise(retarding) in increments until you hear zero ping at every operating condition. I'm guessing that should be around 14 degrees if you run 93. I've noticed that the most sensitive operating condition to ping is at light cruise in 4th with the VCC engaged.
    Angry Matt's Avatar
    Angry Matt is offline Cadillac Owners Enthusiast
    Automobile(s): (2) '81 FWBs, '86 Cutlass Supreme
    May 2009
    Limerick, PA
    38
    690
    Do you have any flea markets near you? Last timing light I picked up was a gently used old craftsman for $2. They're good to have around.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,909
    One degree of timing for a distributor is about the width of a toothpick, maybe less: the distributor rotates at exactly one half engine speed.
    Get a good timing light and set the initial timing to specs by the Factory Service Manual before you hole a piston.
    "Old school" always set timing and did checks with proper lights and equipment: You cannot set timing, ever, nohow, for any reason, by guess or "feel". Do it correctly or break something, big time.
    Don't forget that you're not only adjusting initial timing (vacuum disconnected), but you're also adjusting every other part of the curve from off-idle to max rpm.
    Oct 2008
    Palm Bay, FL
    2,024
    These HEI's are not vacuum advance. I paid $30 for my 'actron' brand light at autozone. Flea market is a great idea. You could also put a want an up on craigslist.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Timing lights may even be available through the "loan-a-tool" programs out there like at Autozone or Advance. Then it's free.
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    Quote Originally Posted by submariner409 View Post
    Really? I set all my timing "by ear" and am usually only a degree off at most (no kidding). I used to do it the garage I worked at for "tips". Made good money....
    Feb 2006
    55,909
    Chris - it's one thing to have shop experience with a lot of engines and setups - it's another to use "turns of 1/2 to 1 inch"...............
    Feb 2009
    Jacksonville, FL
    1,023
    ^^^ Touche'
    Yeah, you start moving a distributor that far and your bound to have trouble....
    quins90lac's Avatar
    quins90lac is offline Cadillac Owners Enthusiast
    Automobile(s): 1990 Cadillac sedan devile
    May 2008
    Peoria IL USA
    35
    616
    i got a timing light at harbor freight for like $13
    carnut is online now Cadillac Owners Master
    Feb 2003
    california
    69
    6,643
    This distributor has a lead from the ECM that advances the timing, without that wire disconnected even with a timing light you have no way of setting static (base) timing. On my 84 it was a wire with a green connector. Once disconnected the timing can be read of the timing marks. Spec I believe is 10 degrees BTDC.
    Oct 2008
    Palm Bay, FL
    2,024
    ^^That's outdated for the 91. You have to jump terminals A and B of the ALDL connector under the dash to get the computer to stop adjusting the timing. The DIC will display 'SET TIMING MODE' and then you can get a reading off the crank.
    Feb 2003
    california
    69
    6,643
    Thanks for the correction!! That is the proper step to see the base timing.
  16. #14
    iamjerry7 is offline Cadillac Owners Member
    Jul 2014
    1
    Quote Originally Posted by the recluse View Post
    ^^^ Touche'
    Yep, if you don't have a clue, you can damage somthin. But if you do a mindmeld with your engine, you can tune it just right. The engine will purr and It will feel right. You'll have to let go of your fear and the left brain, may the force be with you.
  17. #15
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,530
    Quote Originally Posted by Sevillian273 View Post
    The 4.9 seems very particular about the base timing.
    As others said.
    Get a timing light.
    Put the system into 'set timing mode' per above.
    Set with the light to exactly what the book calls for.
  18. Remove Advertisements
