looking for a good 4100 mechanic
Results 1 to 6 of 6
HT4100 4.1, 4.5, 4.9 Discussion, looking for a good 4100 mechanic in Cadillac Engine Discussion; My '84 Eldorado blew a head gasket Sunday. Does anyone know a good 4100 mechanic in the Dallas/Ft. Worth area? ...
    Bob Tarpenning is offline Cadillac Owners Member
    Automobile(s): 1984 Eldorado Barritz Conv
    May 2010
    Cleburne, TX
    82
    12
    My '84 Eldorado blew a head gasket Sunday. Does anyone know a good 4100 mechanic in the Dallas/Ft. Worth area? Will a 4.5 or a 4.9 engine enterchange with a 4.1 in an Eldorado?
    Bob T
    68
    81,926
    Re: looking for a good 4100 mechanic
    Nothing special about the 4100. Any decent mechanic can do it. Hell, I did one in my garage many years ago. Not sure if you can swap in a 4.9, but if you find that you can, go for it. It's 10 times better than the 4100.
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    I don't think the transverse engines will mount in the RWD chassis but I don't know for sure. If I had a RWD Cadillac that I wanted to keep on the road, I'd swap in a Chevy 350 anyway (maybe even something better--sky is the limit on RWD)
    Stingroo's Avatar
    Stingroo is online now Cadillac Owners 10000+ Posts
    Automobile(s): 92 Caprice Wagon LS1/T56 | 1995 Lexus LS400 | Next: 16 MX-5
    Jun 2009
    Port St. Lucie, FL
    26
    18,372
    Check out the RWD forum for inspiration. Greencadillacmatt is finishing up his HT4100 to Olds 350 swap now.
    Feb 2003
    california
    69
    6,643
    First off, this is a front wheel drive car and the engine faces forward. The block design will not allow a 4.5 replacement or later. Have we got water in a cylinder , steam from the exhaust? If not, I would suspect an intake gasket rather than head. Depending on how long the coolant leaked into the engine it could be as simple as an intake gasket replacement or as serious as a worn out camshaft which usually dictates an engine. I've heard some rebuilders offer that block with 4.5 cyl liners allowing you to update. That engine casting is specific to Eldorado and rear wheel drive Fleetwoods.
    May 2010
    Cleburne, TX
    82
    12
    Thanks for the feedback, guys. I've changed the head gasket on a crossways 4100 in a Deville coupe about 15 years ago. Had to do it twice because I used a cheap head gasket the first time. I forgot what it was or what I used the second time. What is the best? I'm 76 now and not really anxious to do it again. I have exhaust gas in the overflow tank so I'm pretty sure it's a head gasket. It is missing on one cylinder also. I started it yesterday and it didn't seem to have water in the cylinder (no water in the exhaust). I'm putting a 4.3L V6 in my '48 Hudson now so it will be a while before I can work on the Eldorado and I'd like to be able to take on a tour in August. That's why I'm looking for a good mechanic near by.
  9. Remove Advertisements
