O2 sensors : 1 righ and 1 lean
Results 1 to 11 of 11
HT4100 4.1, 4.5, 4.9 Discussion, O2 sensors : 1 righ and 1 lean in Cadillac Engine Discussion; Replaced the O2 sensors today. front sensor was grey/white which I believe it means lean, the rear one was black ...
    primerib is offline Cadillac Owners Member
    Automobile(s): 95 Deville
    Aug 2009
    56
    Replaced the O2 sensors today. front sensor was grey/white which I believe it means lean, the rear one was black which appears to be rich. Any ideas what I should take a look at first to get these both back to normal.
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Re: O2 sensors : 1 righ and 1 lean
    The difference in the two sensors could simply be caused by the resulting running condition of one of them failing. Could also be bad injector(s) on one bank or a really bad constant misfire... Check for code E046. How does the car run before/after the new 02 sensors?
    Aug 2009
    56
    car runs okay. seems to be missing/lacking smoothness on acceleration. Kinda poor MPG. I'm betting it's a fuel delivery issue.
    how can I check the injectors in a '95 Deville 4.9L?
    Aug 2009
    56
    okay, I'm grabbing a Noid Light set. I'll try the stethescope trick too
    Oct 2008
    Palm Bay, FL
    2,024
    A noid light will only tell you if the computer is sending a pulse to the injector. Aside from the stethoscope you can also apply voltage to the injector terminals(engine off of course) and listen.
    Feb 2003
    california
    69
    6,640
    If you did not have a service engine now light on and a code related to weak, lazy oxy sensors, you now have 2 good spares. The color of the probe has nothing to do with how they operate. Monitored thru on board diagnostices you can watch the voltage change to verify switching lean/ rich at the right intervals.
    68
    81,917
    Quote Originally Posted by primerib View Post
    Have you checked for a leaky FPR?
    Aug 2009
    56
    yes, I checked the FPR. I pulled the vacuum hose, no leakage
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Use your onboard diagnostics and check block learn and integrator values to determine actual fuel trim instead of guessing what the car is doing.
    Aug 2009
    56
    okay, I've heard of this onboard diagnostic stuff, but how do you do it?
    haynes manual isn't cool enough to have that I guess
    Aug 2009
    56
    oh wait, I found a section in the haynes manual about it. I'm reading now
  14. Remove Advertisements
