Anyone done a 4100 head gasket replace?
Results 1 to 5 of 5
HT4100 4.1, 4.5, 4.9 Discussion, Anyone done a 4100 head gasket replace? in Cadillac Engine Discussion; I have a real nice '85 Deville that I am about to do a head gasket repair on. I have ...
    ShadeTreeJack is offline Cadillac Owners Member
    Automobile(s): 1985 Deville
    May 2010
    57
    I have a real nice '85 Deville that I am about to do a head gasket repair on. I have done cylinder head repair in the past, but struggle with the rear bank on FWD cars. Just wondering if anyone has pics or advice. It IS the head gasket, I will go through the gory details if you wish...overheated, white smoke out the tailpipe, exhaust gas out the coolant cap. need I say more? I will post my progress. - won't be starting for a couple weeks. My son's fwd car needs a clutch. my wife's GM 3.4 L minivan needs a intake gasket - wow there's a surprise ( NOT)
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    Re: Anyone done a 4100 head gasket replace?
    I don't know anybody that has done it successfully. The one person I know of that tried stripped the threads in the aluminum block and ended up replacing it with a junkyard donor.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    I haven't done a 4.1, but I have done 2 4.9's.
    First time I didn't know what I was getting into and stripped the threads on the final torquing stage. The 6 highest torqued (90 ft/lbs?) bolts are on the "upper" (closest to lifter valley) rows of headbolts pulled and I chose only to repair those threads as the other holes felt fine. That was entirely possible in the car, no problem. Not exactly the preferred method, but that engine held fine and ran well till the car was totalled.
    On the next one, I didn't take any chances and pulled the engine to repair all bolt holes, since I wasn't sure I could do it in the car.
    I'm really not sure if you can do the rear bank while the engine is in the car. I really never tried it. Either way, good luck.
    trm
    trm is offline Cadillac Owners Member
    Automobile(s): 87' deville
    Mar 2012
    34
    1
    LightbulbRe: Anyone done a 4100 head gasket replace?
    Attempting my first HG repair, feeling pretty ambitious. I ordered new cylinder heads for about three hundred bucks. New head, manifold and valve cover gaskets cost 120 and change. Just waiting for my thread inserts to arrive and I can begin the reassembly process.
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    You might want to take each lifter out and inspect the cam lobes before you go any further. How does the distributor gear look? One more thing, who's thread inserts are you using? Good luck on the head job and let us know how it turns out.
  8. Remove Advertisements
