rebuilt HT 4100 no oil up top or oil pressure
Results 1 to 9 of 9
HT4100 4.1, 4.5, 4.9 Discussion, rebuilt HT 4100 no oil up top or oil pressure in Cadillac Engine Discussion; i have a remanufactured HT4100 long block noil oil pump how ever i did not prim the pump i have ...
    85caddyeldorado is offline Cadillac Owners Member
    Automobile(s): 1985 eldorado
    Apr 2010
    27
    8
    i have a remanufactured HT4100 long block noil oil pump how ever i did not prim the pump i have started the car and let it run idle for only about a minute tops a little clacking but bone dry up in the top of the lifters ????no one i call will even call me back about this problem
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    Re: rebuilt HT 4100 no oil up top or oil pressure
    I don't remember if the pump can be primed with the distributor removed. My manuals are at the shop. But if you remove the spark plugs so that the engine turns easier, you might try getting it to prime that way, and with the plugs removed, there's no compression pressure on the bearings.
    There is likely assembly lube in the bearings, which should be OK for turning the engine for a bit to prime it.
    Once it's running, if it wasn't run-in at the rebuilding place, you need to break the cam in. 2000 rpm for at least half an hour, or the cam and lifters will get trashed. DON"T LET IT IDLE !!
    Apr 2010
    27
    8
    i have a 1985 remanufactured HT4100 long block noil oil pump how ever i did not prim the pump i have started the car
    and let it run idle for only about a minute tops a little clacking but bone dry up in the top of the lifters ????no one i call will even call me back about this problem please help me ( car starts up and runs , has a little clagking know noise but no oil pressure / oil in top of lifters??
    Mar 2009
    mich
    85
    728
    Did you get that running OK yet??
    Apr 2010
    27
    8
    Re: rebuilt HT 4100 no oil up top or oil pressure (fixed)!!!!!!
    yes ,i took the distribitur out and primed the pump real good untill all oil galleys were oozzing out oil then put all back together and started up and oil pressur is a little ofer 25 psi idle and moves up when u hit the gas and the clattering knoking sound is gone and it runs and sounds smooth, what about adding anti freeze to a new motor do i just pour into radiator??
    PIMED THE PUMP!!!!!!!!!!!!!!!!!!!!!
    86sedandeville is offline Cadillac Owners Member
    Automobile(s): 1986 Cadillac De Ville
    Mar 2012
    33
    I recently bought what was supposed to be a "preped long block" (ht4100) for my '86 deville, from a supplier online when it arrived at my house i was supprized to see a junk yard pull as the engine i ordered. As an aspiring tech, i decided that it could be a good learning experience to go through the engine and rebuild it. i now have an engine that runs great but has a knock with no oil on top of heads or on Rocker assembly i have plenty of oil pressure as i took oil filter off to check pressure. Why no oil on top???????????
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    You have an oil galley that runs along your lifters, from there it travels through the lifter through the pushrod to the rocker arm.
    Mar 2012
    33
    Yes but they were all clean and clear when i put it back together
    83CADMAN's Avatar
    83CADMAN is offline Cadillac Owners Fanatic
    Automobile(s): 83 Eldorado, 90 Seville, 94 Concours
    Jun 2009
    Pacific Northwest
    62
    467
    Quote Originally Posted by 86sedandeville View Post
    Oh man! Thats gota hurt.
    I spotted an ad in a local auto rag for a N*. The picture showed the engine on the floor and the line of BS stated it was low mi, 300 HP, all alum. $1500. What??? I called and got some goober who struggled answering my questions, couldnt tell me what year it was out of. No way to confirm anything without tearing into it. My guess is H/G's. Better odds at the wrecking yard.
    Buyer beware.
  12. Remove Advertisements
