Opinions on my very special '93 FWD C-Body
Page 1 of 3 123 LastLast
Results 1 to 15 of 45
HT4100 4.1, 4.5, 4.9 Discussion, Opinions on my very special '93 FWD C-Body in Cadillac Engine Discussion; She's a 1993 FWD Fleetwood Sixty Special. Ultra MINT, show car, with exactly 10,002 miles on her, or about 50 ...
    Sandy's Avatar
    Sandy is offline Cadillac Owners Master
    Automobile(s): '93 Cadillac 60 Special; '03 Lincoln TownCar Limited ED
    Oct 2003
    Northern New Jersey
    70
    5,929
    She's a 1993 FWD Fleetwood Sixty Special. Ultra MINT, show car, with exactly 10,002 miles on her, or about 50 miles a week, since new.
    She has begun to "smoke" a light grey color outta her tailpipe, upon cold start-up. She will continue to do this until the engine reaches normal opperatiing temperture. If idling and not driven, this takes between 10 & 13 minutes, and then no more smoke. There is a foul oder while it's "smoking" which completely goes away after that above time lapse. She drives beautifully, and never shakes nor wants to stiall. I filled her (took 1/2 a tank with Exxon Supreme 93 grade - but that did not help. She is due for an oil change & filter. any ideas what's "cooking" ??
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,607
    Re: Opinions on my very special '93 FWD C-Body
    Sometimes letting an engine sit is just as or more harmful than accumulating miles.
    When an engine isn't run very often, the top end of the motor can dry out and cause leaky valve stem seals. They get brittle, break, crack, and don't seal well against the valve stem. This is true of most cars at that age, but especially true when they are that low of mileage.
    When this happens, oil drips down (from the last time it was run) onto the top of the valve and gets burned next time the engine is fired up. When that oil gets burned up, the smoking stops until next time it's shut down and oil leaks by the seals again.
    The problem is something that happens with age, not mileage. It generally isn't harmful, as long as it's not enough to foul out spark plugs. I'm guessing yours is minimal since you say it runs smooth.
    69
    82,266
    Does the smoke smell like oil?
    Sandy's Avatar
    Oct 2003
    Northern New Jersey
    70
    5,929
    No, Ranger, it smells like the smell of an old car's backfire.
    Sandy's Avatar
    Oct 2003
    Northern New Jersey
    70
    5,929
    While she is smoking, there is water droplets dropping outta the tailpipe. Both that & and stinky light grey "smoke" coming out of the tailpipe totally stop at 14 minutes of running. they both start IMMEDIATELY upon start-up after NOT being run for 5 or more hours
    Oct 2004
    Oak Creek, WI
    5,607
    The water droplet are most likely just normal condensation in the exhaust as the car warms up.
    I'm still thinking valve seals.
    However, few items in your description also point at a rich condition, mainly the grey color and bad smell. The problem is I don't see how the car could run rich when cold, as the car runs off standard fuel mapping until the o2 sensors are ready and the pcm goes into closed loop. As with others, I guess leaking fuel components could be the cause, but usually that clears up within a few seconds, not 15 minutes. Unless, that is, something is constantly leaking by like a stuck injector or something.
    You could give it a shot anyway. Start off easy by checking the fuel pressure regulator for fuel in it's vacuum line.
    Sandy's Avatar
    Oct 2003
    Northern New Jersey
    70
    5,929
    Could old fuel in the tank cause this? The fuel is about 2 years old, but I added 5 gallons to it, when I had her out, 3 weeks ago. Still does the light grey smoking trick. I want to try this, first.
    Take her out and onto the interstate. Drive her about 20 miles (10 down / 10 back at 60 MPH and then back to her storage garage. Wait 2 days and go start her & see what she does.
    The Caddy dealers are few & far between and the one I used only once before to fix the trunk pull-down is very very expensive. If I HAVE to go to them, then I will....
    Oct 2004
    Oak Creek, WI
    5,607
    Quote Originally Posted by Sandy View Post
    2 year old gas??? Really???
    I didn't know that, I'd definitely start there.
    You can't let that car sit there like that, it's going to deteriorate FASTER than if you just drove it every now and then. Who knows how much water is in the tank from 2 years of condensation occuring...if it gets extreme enough, you are going to get failing fuel system components.
    If you are that anal about mileage, I'd recommend you drain that tank and refill it with fresh fuel and some Stabil
    I'd also recommend you at least run 2 tanks of gas through it every year.
    Low mileage isn't even something to pride yourself on. Low mileage means nothing when the car went to hell from sitting there. Age kills a car, not mileage. You can't eliminate the aging process but you can help keep it in shape by driving it more frequently. I'm not saying you have to put 10,000 miles on it per year, but you have to drive it more than that.
    Besides, it's a car, it's made for driving. If you aren't driving it and enjoying what it was made for, what's the point of having it?
    Sandy's Avatar
    Oct 2003
    Northern New Jersey
    70
    5,929
    Sounds exactly like you & my wife were speaking !!!
    SOooo, I will take her out, and go down the Garden State Parkway for 10 miles around 60 MPH and back the 10 miles and back into storage. Wait 1 day and go over there and start her up, and then report the finding, here.
    IFnot raining this Sunday, I will do it this Sunday & we will take it from there, and by the way, THANKS !
    Here: http://www.smatarese.com/forum/sandy/
    Sandy's Avatar
    Oct 2003
    Northern New Jersey
    70
    5,929
    Drewsdeville, it's not the mileage on her, it's the fact that there are no NOS parts for 1993s, ans especially for the 60 Special, of which were 1% of total 1993 Caddy production, and the last year for the Sixty Special. 1938-1993.
    This is New Jersey, home of the spoert of tailgating, and cutting off and especially speeding 40 MPH in 25MPH zones. Nearly every car older than 2 years old is damaged. To be 100% honest, I am scared to death to take her out. If they don't bump/hit her, when ya park, they will door ding you and if you park far away to prevent that, they will steal your wheel centers and / or your fender skirts, or yank off your hood emblem.
    A friend with a 1992 Eldo took it out to dinner with his Mom and they were inside eating for (he says) under 45 minutes. When they returned he had lost a hood emblem AND had a small verticle scratch on his driver door, from the car next to him. It was the 1st time the car had been out, since last October (2009). They all own/drive honda/toyo and they are leased and not theirs and are just "Transportation" and in 30 months they get a new one.....'Ya know, "it's JUST a car" ..... is their motto.....
    That is why I don't take her out. Ya know SOMETHING is gonna happen, you just do not know when, when driving or when parked.
    Oct 2004
    Oak Creek, WI
    5,607
    I understand that, but also understand that none of that matters when the car falls apart mechanically from everything drying out and sitting in 2+ year old gas. Your current problems could be just the beginning of a royal nightmare if you don't use that car as intended. You don't have to use it as a daily driver, but it may be to your advantage to use it more than you have been.
    If you are living in fear for that car, it can't be enjoyable to worry about it all the time.
    If you want to own something that's pretty to look at, there are lots of collectible art pieces out there. A 1993 Deville (or any car at all) is not for looking at, it's for driving and enjoying it's mechanical ability.
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    ^^^^Agreed^^^^
    I never did understand the fascination with paying a lot of money for something you NEVER use. Think of all the money wasted on registration and insurance
    Drews right though, your troubles just beginning with a car that does nothing but sit...
    Sandy's Avatar
    Oct 2003
    Northern New Jersey
    70
    5,929
    CONVINCED !!!!
    Sunday Morning, 9AM she is going out, and down the New Jersey Garden State Parkway (65MPH speed limit) for 20 miles south and then 20 miles back north, home. She idels super smooth and is extremey quiet.
    She has 12 gallons in her. Should i do the ride with that, or top it off? I seem to think not to top it off, just yet. What say the experts?
    PS/ Wife says thank you for telling him to use the XXXX thing!!
  16. #14
    hueterm's Avatar
    hueterm is offline Moderator
    Automobile(s): See my sig...
    Aug 2005
    Bentonville, AR
    45
    8,096
    Don't you have some other cars in storage too? If so, you should do the same to them...
    NOW
    '04 Escalade EXT (8/07-?)
    '70 Grand Prix Model J (4/09-?)
    '95 Roadmaster Estate (4/10-?)
    '94 Roadmaster Estate (5/10-?)
    '08 DTS Platinum (2/11-?)
    '97 Riv S/C ('06-08 and 8/11-?)
    '85 Toro Caliente (4/14-?)
    '95 Deville Concours ('07-11 and 4/15-?)
    '97 Town Car Sig (4/15-?)
    PAST
    '92 Toronado ('95-99)
    '99 Grand Prix GTP ('99-02)
    '02 Avalanche North Face ('02-04)
    '93 Roadmaster ('04-07)
    '04 Avalanche Z71 ('04-07)
    '00 Eldorado ETC ('08-11)
    NEXT
    '71-72 Riv
    '86-91 560SEC
  17. #15
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    My advice to the 90-yr-old neighbor who doesn't drive much is don't park with more than half a tank, that way you are always able to add fresh gas when you take it out again
    As to the original question you might be looking at intake gasket problems, it's pretty common with these engines
  18. Remove Advertisements
