chugging and backfiring intermittently. No codes - Page 4
Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 71
HT4100 4.1, 4.5, 4.9 Discussion, chugging and backfiring intermittently. No codes in Cadillac Engine Discussion; I let the car run in my garage for about a half an hour. I still don't have my rear ...
  1. #46
    red_ghost is offline Cadillac Owners Fanatic
    Automobile(s): 1991 Deville, 1995 Deville
    Nov 2005
    Green Bay Wi
    29
    220
    Re: chugging and backfiring intermittently. No codes
    I let the car run in my garage for about a half an hour. I still don't have my rear hydraulic cylinder back yet so I can't drive it. the front injectors were all between 16.5 and 16.8 OHMs. The rears were between 17.1 and 17.4 OHMs.
  2. #47
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    Change the TPS. I had the same kind of problem, wound up changing the MAP and the TPS and finally had to put in a new ISC adjuster. I'll hook the battery up tomorrow to find out if that's that last issue or not. A TPS and MAP change though has the whole motor running real smooth with good throttle response, the ISC screwed that all up when it decided to quit...
  3. #48
    donwon is offline Cadillac Owners Enthusiast
    Automobile(s): 92 Deville
    Sep 2004
    SC.
    548
    You said the fuel pump was changed about 4 years ago??? Could be the bushings are wearing on the pump and binding at some point,
    causing the fuel presure to drop.
    I changed out most electrical sensors on my 92 Deville, when that didn't help I put a fuel gauge on the fuel rail and used duct tape to tape the gauge to the windshield and drove the car watching the pressure gauge till it started flucuating, then I knew the fuel pump was going bad.
    Only doing the chuging spitting and poping under a load led me to believe it was in the ignation system. I used a Mallory pump and it has lasted 3 years so far.
    I also changed the tank because of the plastic baffel being broken.
  5. #49
    Nov 2005
    Green Bay Wi
    29
    220
    I have a brand new fuel tank sitting in my shop. Going to paint it this week, then probably buy another fuel pump.
  6. #50
    Sep 2004
    SC.
    548
    Less trouble and faster to do the pressure gauge, unles you just like to do this kind ofstuff.
  7. #51
    Nov 2005
    Green Bay Wi
    29
    220
    Quote Originally Posted by donwon View Post
    true, but if im putting on a new gas tank, I might as well put a new pump in anyway.
  8. #52
    Sep 2004
    SC.
    548
    How right you are. I didn't relize you were gonna change the tank anyway.
  9. #53
    Nov 2005
    Green Bay Wi
    29
    220
    yessir. I was going to chrome the undercarriage this year, but i decided to move into a bigger house instead. my current gas tank is all rusted and looks like crap.
    Right now i'm putting on some custom LED tail lights I made. I'll put pics up here once I get them finished.
  10. #54
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    I wish the gas tank was the only thing rusty on mine!
  11. #55
    Nov 2005
    Green Bay Wi
    29
    220
    Well, looks like i have bigger problems now. one of the sidewalls on teh inside of my tire is all ripped up and its slowly leaking air. not sure how that happened. there is a ton of construction here. also one of my back wheel bearings needs to be replaced. That'll be my project for tomorrow (tonight is my sons 2 years old birthday). Also here's pics of my new tail lights:
  12. #56
    Nov 2005
    Green Bay Wi
    29
    220
    the above pictures didnt seem to work. Here:
    no lights:
    running lights:
    running lights and turn signals:
  13. #57
    DNE
    DNE is offline Cadillac Owners Member
    Automobile(s): 84 eldo. cov.
    Aug 2009
    61
    16
    I have a 4100 throtle body inj. eng in a 84 eldo, had same problem, after all was said and done it was the dist.
  14. #58
    Dee911Lady is offline Cadillac Owners Member
    Jul 2010
    1
    Did the gas tank and fuel pump resolve this problem? I am having the same problems with my car now. It is currently in the shop and nothing is showing up as a problem. I assume by the last response you replaced the fuel tank and fuel pump and this solved the problem. Please let me know.
  15. #59
    Nov 2005
    Green Bay Wi
    29
    220
    I never solved this problem. I haven't done much to correct it. $ been low. It hardly ever happens now. Seems to happen when its rainy or cold (i don't drive teh car at those times though).
  16. #60
    DNE
    Aug 2009
    61
    16
    hi, not sure what engine you are talking about, I had a 4.1 do this after a long time trying to fig. it out turned out to be a bad dist. put in rebuilt runs great since.
    DNE
  17. Remove Advertisements
