chugging and backfiring intermittently. No codes - Page 2
Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 71
HT4100 4.1, 4.5, 4.9 Discussion, chugging and backfiring intermittently. No codes in Cadillac Engine Discussion; The MAP sensor was probably the issue from the start. They can be going bad and never trip a code. ...
  1. #16
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    Re: chugging and backfiring intermittently. No codes
    The MAP sensor was probably the issue from the start. They can be going bad and never trip a code. They can be had for about $50 to $65 and may just be worth it to replace.
  2. #17
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Rock auto has them for $30. But dont get too excited..... Same code happened to me when my car stalled due to a bad ignition module.
  3. #18
    Feb 2009
    Jacksonville, FL
    1,023
    Quote Originally Posted by red_ghost View Post
    The ignition module, cap, rotor, wires, plugs, o2 sensor, oil pressure sensor, tps, isc motor are all about a year old.
    That's why I ruled it out, but it is an easy enough item to get it checked. OP, take it out and take it to your local parts store that is capable of checking the ignition module and have it tested.
    I looked on Rock Auto but couldn't find the MAP sensor....got a link? Even at $30, it's well worth a switch...
  5. #19
    Oct 2008
    Palm Bay, FL
    2,024
    Standard motor products http://www.rockauto.com/catalog/x,ca...parttype,11207 I have the even less expensive KEMPARTS one and it works fine.
  6. #20
    red_ghost is offline Cadillac Owners Fanatic
    Automobile(s): 1991 Deville, 1995 Deville
    Nov 2005
    Green Bay Wi
    29
    220
    Took it to the dealer because all my tools were packed. They said it was because some of the ground points on the fender were corroded. thats a load of bull, because I stripped them down to bare metal, and painted everything last year. after that I ground it with a wire wheel. Then they blamed it on my ignition wire sagging too low and hitting the exhaust. It didn't do that until I brought it in to them. I would have noticed the melted plastic wireloom on the manifold. It still does it. I'm going to buy a new MAP sensor and home thats what it is. The dealer said its probably not that.
    gas milage is also not very good.
  7. #21
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Well, you can get some satisfaction in the fact that your Cadillac techs aren't any smarter than you are. They tried to make it sound good anyway. These problems are very tricky to diagnose so it does require a certain amount of luck too. I don't believe a MAP sensor will cause a backfire but it is nice to have a spare around when there is a question about it. Is this condition affected by rain or humid weather?
  8. #22
    Nov 2005
    Green Bay Wi
    29
    220
    I don't drive the car in the rain, and its not very humid here. It didn't seem to do it as bad today, and it didnt back fire today, only chug slightly. I had to run to the store and pick up something and it stalled on the way out, but without chugging. I did notice that my car's exhaust was more visible than a lot of the other cars on road. Its about 35 degrees here this morning. Once agian, no codes other than e91. no check engine light.
  9. #23
    Feb 2007
    Maine
    55
    3,310
    I think at this point, since we're no closer to finding the problem, that I would think about purchasing a new distributor. If they are less than $200 I would take the plunge. Or, ...completely disassemble your distributor and reassemble it with the utmpst TLC.
    I would also think about temporarily wiring a voltage gauge to the dist 12v wire to monitor the voltage going into the distributor to make sure that it is constant. I guess I would do this first before purchasing a new dist.
  10. #24
    Nov 2005
    Green Bay Wi
    29
    220
    Do you think the hall effect sensor woudl have anything to do with it? My grandpa had some ignition problems with his 94 and thats what it turned out to be.
    Also this car does not have the factory bcm and ecm. I took the main interior wiring harness out and switched it for one from a 92 with a digital dash. I also used that bcm and ecm. I never switched over teh prom chip. Could that matter?
    Also the dealer is not calling me back. lol
  11. #25
    Feb 2007
    Maine
    55
    3,310
    The hall effect sensor is known to fail at some point. I would suspect it just because it's about the only thing that hasn't been replaced yet. I don't think the BCM would be related because when mine failed, and the dash lights would flash and the BCM would click, the car still ran fine. I'm pretty sure it's either a problem inside the distributor or it's momentarily losing it's 12 volt power for some other reason.
    That would be a pisser if it turned out to be those Bosch plugs. I didn't bash tem at first because I kinda like the regular platinums but I'm not sold on the plus 4 things.
  12. #26
    Nov 2005
    Green Bay Wi
    29
    220
    Because of it running fine last year, I doubt its the plugs. I drove from northern WI to IN last year with them...
    I talked to the dealer this morning; I think I'll throw a few more parts at it, and if its not fixed; then I'll take it back. I need it fixed soon, because I plan to go to a car show in Toronto with it on July 18th (that's a 13 hour drive for me).
  13. #27
    Nov 2005
    Green Bay Wi
    29
    220
    Im going to replace the prndl switch and map sensor to start with.
  14. #28
    Nov 2005
    Green Bay Wi
    29
    220
    On my lunch break when I started up the car and was still in park, it was idling very high and started chugging. After about 3 or 4 seconds my Check Engine Light came on and I got E31 again. So, im pretty confident that is what the problem is. I ordered both parts new at Rock Auto.
  15. #29
    Feb 2007
    Maine
    55
    3,310
    Piece of cake if that's all it is. My MAP died once while I was on vacation and it was stalling and chugging at red lights. It didn't backfire though so I didn't associate it with your problem. Good luck.
  16. #30
    Nov 2005
    Green Bay Wi
    29
    220
    my idea is that the backfire was caused by too much fuel, as if its the map sensor, it could be outputting too much fuel. what particles don't get burnt in the engine ignite in the cat converter. This is my theory because it doesn't backfire right away. If it chugs, it takes maybe 4 to 5 seconds before it backfires.
  17. Remove Advertisements
