4.9 fuel pump question
Results 1 to 3 of 3
HT4100 4.1, 4.5, 4.9 Discussion, 4.9 fuel pump question in Cadillac Engine Discussion; Does anyone know the flow of the stock 4.9 fuel pump in gph or lph? Can't seem to find this ...
    Ghost C's Avatar
    Ghost C is offline Cadillac Owners Fanatic
    Automobile(s): '91 Sedan DeVille Silhouette Special
    High Point, NC
    31
    439
    Does anyone know the flow of the stock 4.9 fuel pump in gph or lph? Can't seem to find this info anywhere.
    Switching to a fuel cell/inline pump and I don't want to go overboard on the fuel pump size.
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Re: 4.9 fuel pump question
    I wouldnt worry about it as the FPR will keep the fuel pressure in line. An extra large pump will just result in more fuel returned to the tank. Only an under sized pump would cause a problem and I doubt any after market pump would flow less than an oem.
    Ghost C's Avatar
    High Point, NC
    31
    439
    The problem is too large of a pump will heat the fuel and cause undue stress on the entire system, causing things to wear out prematurely.
    I'm looking at either a Trick Flow or Summit 43gph. I think the Walbro 255lph (65 or so gph) is entirely too large. If anyone can chime in with a definite flow number for the stock unit, I'd greatly appreciate it.
