Steering
Results 1 to 6 of 6
HT4100 4.1, 4.5, 4.9 Discussion, Steering in Cadillac Engine Discussion; I have a mild knock-knock sort of sound when turning left lately. It isnt a bearing or wheel based sound, ...
    MrDobin is offline Cadillac Owners Fanatic
    Automobile(s): 1985 Cadillac Seville Elegante
    Feb 2009
    27
    222
    Steering
    I have a mild knock-knock sort of sound when turning left lately. It isnt a bearing or wheel based sound, I shifted into neutral on flat ground to verify and didnt roll or allow brake use. I also think the steering fluid is on the used up end of things. Smell is clearly of the past due scent. Is there a drain point on the steering to do a refill and see if the sound stops? i havent noticed a loss of power and it seems out to be only one way when turning. Possibly the pitman arm needing change?
    68
    81,929
    Re: Steering
    Changing the P/S fluid won't help. Whatever it is is a mechanical problem.
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    Re: Steering
    I would suspect rack and pinion is dead or dying. If your fluid is blackish it's probably from the bearings and gears. Fluid should be replaced regardless but it won't fix worn gears.
    Is your car FWD or RWD?
    Feb 2009
    27
    222
    Re: Steering
    Fluid seems ok, was half awake checking it. Though the sound is so slight and few notice unless dead silent since I have a paranoid ear. Its a tick tick but not noticeable unless very attentive. I am gonna lift the car and check the wheel. No sounds otherwise and beside a pitmon arm issue to replace, theres nothing to report. Not sure till i check it out this weekend. Its FWD
    Feb 2003
    california
    69
    6,643
    Re: Steering
    Has no rack and pinion gear box. I would suspect the gear box to frame bolts first then a loose caliper to spindle bolt. Make sure when checking that all 4 drive axle boots are intact. A worn dry CV joint will click. To change P/S fluid you must loosen the pressure hose at the gear box and let it drain while adding fresh fluid.
    Feb 2009
    27
    222
    Re: Steering
    Yea. I had a friend mention the tie rod may likely be dried or worn. Its annoying because whatever I find it is, its only audible IN the friggen car. Not outside.
  9. Remove Advertisements
