Results 1 to 10 of 10
Thread: getting wierd OBD I codes what is it bad computer?
    mike93 is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Cadillac sedan deville
    Sep 2009
    Media, Pennsylvania
    26
    281
    Hey everyone how are you? Everyonce in a while i check to see if i have any codes i checked yesterday and today and I keep getting E7.0 back and forth and then says E00 back and forth what could it be those are not even codes am i right or wrong?
    69
    82,281
    Re: getting wierd OBD I codes what is it bad computer?
    You have no codes. 7.0 means that it is ready to go to the next mode.
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    The diagnostic system on these cars has amazing capability if you know how to use it ( i don't!!) Every switch can be checked etc. I've been into it a few times, but didn't pursue it beyond what I wanted to know to fix something.
    Like if it ain't broke, don't mess with it
  5. #4
    MrDobin is offline Cadillac Owners Fanatic
    Automobile(s): 1985 Cadillac Seville Elegante
    Feb 2009
    28
    222
    I wouldn't worry about it. These things DO do a lot as said already. And its always chance they may act up with age. If you feel its running well and nothing to worry on. I wouldnt freak. Unless codes consistently show for something specific, see how it goes.
  6. #5
    Sep 2009
    Media, Pennsylvania
    26
    281
    ok thanks i know when 7.0 comes up it means no codes it always used to do that but never with an e7.0 thats something new thats why I asked it's hesitating but thats probably because it doesn't have ac delcos and 2 different sets of wires that stupid aamco did when i specifically told them to change all the spark plugs and wires with ac delcos
  7. #6
    Feb 2009
    28
    222
    I couldn't tell ya on that aamco stuff. I am just always sure when I replace, its the closest or exactly, to the originals.
  8. #7
    Sep 2009
    Media, Pennsylvania
    26
    281
    yeah it's hesitating and bogging down
  9. #8
    Mar 2009
    mich
    85
    728
    Not likely any problem with plug wires. Kinda sounds like a fuel problem, or maybe EGR operation. The book mentions the Cat converter too. I would think the EGR would show a trouble code though.
    I don't remember all the things you fixed so far. Fuel filter?
    Bad/ intermittent grounds are also mentioned.
  10. #9
    Sep 2009
    Media, Pennsylvania
    26
    281
    ive replaced fuel filter egr valve tps catalytic converter ignition coil cap and rotor i think thats it maybe more just forgetting
  11. #10
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Have you checked fuel pressure? Also an injector stuck open will cause those symptoms too.
  • You may not post replies
