Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: need help antifreeze leak 4.9 1993 deville
  1. #16
    mike93 is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Cadillac sedan deville
    Sep 2009
    Media, Pennsylvania
    26
    281
    Re: need help antifreeze leak 4.9 1993 deville
    yeah that hose clamp was really loose thats where it leaked from when my neighbor pressure tested it
  2. #17
    CorpBlack is offline Cadillac Owners Member
    Automobile(s): 1991 Cadillac Deville Sedan
    Apr 2010
    16
    I have that same issue, I just replaced the water pump yesterday, put a brand new one in and it is still leaking from the same spot. at the botttom of the pump to the left of the spindle it drips. does this sound like your problem Mike?
    Also, if it is, what is the easiest way to get at this sequence of pipes/tubes? Are they rubber tubes or solid (break line type) tubes
  3. #18
    Sep 2009
    Media, Pennsylvania
    26
    281
    mine was the water pump after all did it yesterday i had it pressure tested and it leaked from the water pump so just replaced it yesterday with brand new water pump
  4. #19
    MrDobin is offline Cadillac Owners Fanatic
    Automobile(s): 1985 Cadillac Seville Elegante
    Feb 2009
    28
    222
    Agreed. The water(that name pisses me off given its not water and having one blow up mid winter is a b****) pump going out would be a nightmare. Coolant shoots off on the belts and makes a fine mess of things. Glad its a simple fix this time.
  • You may not post replies
