cooling fan module
Results 1 to 3 of 3
HT4100 4.1, 4.5, 4.9 Discussion, cooling fan module in Cadillac Engine Discussion; My '85 FWD Fleetwood cooling fans run all the time. I have to assume that the module is bad. It's ...
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    cooling fan module
    My '85 FWD Fleetwood cooling fans run all the time. I have to assume that the module is bad. It's been that way since I've owned it. The module on this one is wrapped in the harness, (weird) and a new one seems unavailable. Anyone heard of a different year, or different GM car module being modded to fit?
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    Re: cooling fan module
    I have that same controller on my 85. I used to see them on ebay but just looked and don't see any now. I figure I'll have to go with an aftermarket controller when the time comes but it will be tough to integrate with the BCM (it sets F41 and trips the coolant/fan light if it doesn't get the expected feedback). There are a few tests you can run to see if the problem is with the command wires from the BCM to the FCM, or with the monitor wire, or with the fans themselves. If you don't have an FSM a competent shop should be able to do the tests from alldata.
    ehall's Avatar
    Aug 2007
    Southern Maryland
    1,883
    ps--I just remembered that AC Delco used to list one in their online parts database but don't any longer. They may still have one available.
    ebay motors has one
