4.9 a little jittery at idle
Results 1 to 9 of 9
HT4100 4.1, 4.5, 4.9 Discussion, 4.9 a little jittery at idle in Cadillac Engine Discussion; Folks: The ole 4.9 is running pretty darn well these days after the new distributor -- but at idle, in ...
    EldoRedo91 is offline Cadillac Owners Member
    Automobile(s): Eldorado
    Jun 2009
    22
    Folks:
    The ole 4.9 is running pretty darn well these days after the new distributor -- but at idle, in gear, it now seems just a little jittery to me, based on past experience. But "past experience" is a little hard to quantify! The idle RPM is correct, and I have no codes. But what's reasonable to expect? I seem to remember it purring calmly at stop lights, imparting no (admittedly subtle) "jitteriness" to the driver through the brake pedal and steering wheel.
    Is this something that can be addressed, and if so, what needs to be done? BTW this is a rebuilt engine with less than 10K on it...
    Thanks for any input.
    I~LUV~Caddys8792's Avatar
    I~LUV~Caddys8792 is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 Town Car Cartier & 2014 Accord LX MTX
    Dec 2004
    Roseville, MN.
    30
    34,087
    Re: 4.9 a little jittery at idle
    4.9's by and large, have a bit of a lumpy idle. I guess it's just a lopey cam. I remember mine having a bit of a lopey idle as well. They smoothed it out in '94, but the early ones are lopier.
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    I might guess motor mounts but I assume they were replaced when the engine was rebuilt? What about the top mount at the radiator? Are the injectors original?
    Jun 2009
    22
    Yes the motor mounts were replaced -- not sure about the injectors.
    justin4yu is offline Cadillac Owners Member
    Automobile(s): 1992 Cadillac Fleetwood 2door sedan
    Jun 2010
    Yelm, Washington, United State
    31
    31
    does the exhaust have a spiting sound to it?
    daniel58 is offline Cadillac Owners Fanatic
    Automobile(s): 58 Coupe Deville, 77 Coupe deville, 90 Deville
    Sep 2009
    183
    I am having a similar problem with my 4.5 (a few posts above yours) I haven't really got an answer to my question about getting the distributer 180 degrees out. But I can tell you that double checking the timing may help and check those plug wires, they are easy to get mixed up
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,607
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    I agree, the engine idle was never dead smooth. The 4.9 was famous for that minor complaint. All you can do is make sure every plug has the same gap and all the plug wires measure proper resistance.
    Jun 2009
    22
    For what it's worth, this jitteriness has cleared up on its own over the past two months or so.
  12. Remove Advertisements
