Power brake booster vacuum hose? All Cylinders?
Results 1 to 4 of 4
HT4100 4.1, 4.5, 4.9 Discussion, Power brake booster vacuum hose? All Cylinders? in Cadillac Engine Discussion; Does the Power brake booster vacuum hose feed all cylinders on a 92 Seville with the 4.9L? Need a little ...
    4.9L BEAST!!'s Avatar
    4.9L BEAST!! is offline Cadillac Owners Member
    Automobile(s): 1992 Seville
    Mar 2010
    QuestionPower brake booster vacuum hose? All Cylinders?
    Does the Power brake booster vacuum hose feed all cylinders on a 92 Seville with the 4.9L? Need a little knowledge on this subject, help me out.
    69
    82,155
    Re: Power brake booster vacuum hose? All Cylinders?
    The hose is a vacuum hose. It does not feed anything. It is "fed" by the intake manifold and supplies vacuum to the booster.
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Yes, all cylinders contribute to the vacuum that is applied to the brake booster. A leak in the hose will affect all cylinders the same.
    Mar 2010
    Thanks for the help!
  7. Remove Advertisements
