Egr
Results 1 to 12 of 12
HT4100 4.1, 4.5, 4.9 Discussion, Egr in Cadillac Engine Discussion; Ok I want to clean my egr, I know if it's not broke, don't fix it. But it's something that ...
    jwcummings's Avatar
    jwcummings is offline Cadillac Owners Fanatic
    Automobile(s): 1990 Seville
    Jan 2010
    Charlotte, NC and Philly
    43
    108
    Egr
    Ok I want to clean my egr, I know if it's not broke, don't fix it. But it's something that I think has never been change or cleaned on a 20 year old car. Now how in the hell do I get it off? Do I have to modify another wrench? Also want to chang my injectors, does anyone have any recomendations? I heard to go with 18psi. Thanks in advance.
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Re: Egr
    I bent I think a 13mm box wrench 90 degrees to get at mine. It helps to remove the brake booster hose... Also a distributor wrench might work. Buy a gasket for it before you remove it. Honestly if it's not setting codes and your engine isnt pinging then I would leave it alone. Take a look down in the throttle body at the 2 small tubes pointing up. Make sure they are not clogged shut with carbon.
    19lb injectors for mustangs, ford explorers, crown victorias, etc will work and are cheaper but it is always best to go with the flow rate that was intended for the engine so that the control system doesnt have to adjust...
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,112
    Re: Egr
    Yeah, leave the EGR valve alone.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Re: Egr
    If you want to do the EGR, I recommend taking off the throttle body. It makes getting at the EGR a snap and also allows for excellent cleaning access to the throttle body itself and the EGR tubes. It's really easy to get the throttle body off. Once you count in the time it takes you to work with the tight spot the EGR is in, it probably takes the same amount of time just to do it this way...
    jwcummings's Avatar
    Jan 2010
    43
    108
    Re: Egr
    ok thanks for the feed back still debating
    68
    82,062
    Re: Egr
    I think on the 4.9 cleaning the EGR tubes in the TB is more important than the EGR itself.
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,112
    Re: Egr
    Quote Originally Posted by drewsdeville View Post
    Ditto.
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    Re: Egr
    Of course if you remove the throttle body, you need a new gasket for that too, since the old one may not seat exactly where it was before you removed it. Just a pre-caution to prevent a leak.
    jwcummings's Avatar
    Jan 2010
    43
    108
    Re: Egr
    ok I have the 4.5 MPFI where are the egr tubes in this TB?
    Oct 2004
    Oak Creek, WI
    5,609
    Re: Egr
    under the throttle blades.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: Egr
    If it ain't broke don't fix it. I would just clean the tubes and call it good like Ranger said.
    jwcummings's Avatar
    Jan 2010
    43
    108
    Re: Egr
    ok got the code 48 today took the egr and tb off and cleaned them today, new gaskets and vac. hoses Purrs like a kitten and has alittle more peep in her step
  15. Remove Advertisements
