EGR tubes and TPS question.
Page 1 of 2 12 LastLast
Results 1 to 15 of 19
HT4100 4.1, 4.5, 4.9 Discussion, EGR tubes and TPS question. in Cadillac Engine Discussion; I have some maintenance to do on my Deville and as such, have a couple of questions dealing with the ...
    ga_etc's Avatar
    ga_etc is offline Cadillac Owners Connoisseur
    Automobile(s): '08 DTS Lux III Blk Cherry, '89 Brougham d'Elegance Dip Blue
    Dec 2008
    Chickamauga, GA
    31
    4,847
    I have some maintenance to do on my Deville and as such, have a couple of questions dealing with the 4.9. 1. Is there a specific way to clean the EGR tubes? One of them is completely clogged with carbon so that needs to be taken care of. 2. I think the TPS needs to be replaced and was told that on some cars they have to be "programmed". Is that the case with these motors? I have got to get this car getting better gas mileage.
    Ranger is online now Cadillac Owners Member
    69
    82,182
    Re: EGR tubes and TPS question.
    Rod out the EGR tube with whatever it takes, coat hangar, screwdriver, etc. Don't worry about the TPS until that is done. That may be all you need.
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    If you replace the TPS it will have to reset. If the car doesnt coast down when you let off the gas then it may be out of whack but otherwise it's probably fine.
    ga_etc's Avatar
    Dec 2008
    Chickamauga, GA
    31
    4,847
    Went over to a friend's house and cleaned the TB. He kept spraying and spraying till the whole can is nearly gone. Now the car is keeping it's self idled up to the point that it was maintaining around 50 mph on it's own coming back down the road. Maybe that will evaporate out of the system over night and it will act better tomorrow. If not, any other ideas?
    Oct 2008
    Palm Bay, FL
    2,024
    The carb cleaner will be eliminated in minutes if not seconds. I guarantee it was gone before you shut the hood.
    Its likely your TPS is out of adjustment...
    Enter diagnostics and go into 'ECM OVERRIDE?' Whne you get to ISC, press the 'cooler' button and watch the ISC plunger retract until it does not touch the throttle lever.
    Then press 'off' and go into 'ECM DATA?' and the first listing will be TPS. Watch the number count down while the ISC is still retracting which takes about 20-30 seconds. When it stops counting down it should be between -.5 and .5. Its likely that yours is outside of the range.
    ga_etc's Avatar
    Dec 2008
    Chickamauga, GA
    31
    4,847
    I know nothing about going into the system on these cars. It is much easier to do on my ETC. ISC?
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,117
    If it is clogged badly you may have to use a drill bit (FSM recommends).
    Oct 2008
    Palm Bay, FL
    2,024
    Quote Originally Posted by ga_etc View Post
    Try the sticky at the top of the forum. I'm familiar with the Eldo/Sevilles's DIC, not the Deville. ISC is 'Idle Speed Control' motor.
    69
    82,182
    Spray alone will not do it. You have to rod that hardened carbon out.
    ga_etc's Avatar
    Dec 2008
    Chickamauga, GA
    31
    4,847
    We took a coat hanger and cleaned it out.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Now that it's all cleaned out, it sounds like it is idling too high. I would disconnect the battery for 10-15 min and go through the idle relearn process outlined in the owners manual. It may idle fine without the idle relearn because it will default to clean throttle body setting but I usually do it anyway.
    ga_etc's Avatar
    Dec 2008
    Chickamauga, GA
    31
    4,847
    I disconnected the TPS for a min and hooked it back up. The idle is back to where it should be. I cleared the codes and after driving the car, no codes have popped back up. E55 is gone, but the slight rough idle and jump/sputter under light load is still there and gas mileage hasn't improved. At this point I'm thinking fuel delivery problem somewhere. It accelerates fine so I doubt it's a fire problem. I'm thinking the fuel filter is getting stopped up, but not sure.
    69
    82,182
    If the filter was the problem the engine would starve for fuel under high fuel demands such as highway driving or WOT. If that's not the case, forget the filter.
  16. #14
    ga_etc's Avatar
    Dec 2008
    Chickamauga, GA
    31
    4,847
    Well it's not starving for fuel. If anything I think it's running a little rich. I'm lost with this thing. It accelerates fine, and feels like it has the power it should. I don't know where to start.
  17. #15
    69
    82,182
    Have you checked for a leaky FPR?
  18. Remove Advertisements
