Ground Locations?
Results 1 to 8 of 8
HT4100 4.1, 4.5, 4.9 Discussion, Ground Locations? in Cadillac Engine Discussion; Where are all the grounds located on the 86-91 Sevilles / Eldo's? One is the flat braided line at the ...
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Ground Locations?
    One is the flat braided line at the rear alt pivot but where does it go from there?
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    Re: Ground Locations?
    The factory manuals have all the grounds listed and diagrammed, and there are a lot of them. They are under the dash near the door posts, behind the rear seat back-rest etc as well as in the engine compartment. Near the battery tray there are some also, at least on mine.
    Oct 2008
    Palm Bay, FL
    2,024
    I thumbed through the manual and didnt find them all in one place. They seem to be scattered about in areas that pertain to specific grounds.
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 118,*** miles
    Dec 2005
    MA
    58
    2,128
    Behind the passenger side head light. On the engine block next to the starter (8 x 1.25 mm stud).
    Oct 2008
    Palm Bay, FL
    2,024
    Thanks! I just found one behind the battery in a plastic box labeled 'ELECTRONICS GND'. Seems pretty loose Going to investigate further tomorrow...
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,128
    Quote Originally Posted by Sevillian273 View Post
    These grounds get corroded because of close proximity of the battery. Clean them up with a wirebrush.
    Oct 2008
    Palm Bay, FL
    2,024
    Funny there is no direct wire from the alt case to the negative batt terminal. The braided wire goes from alt to block( about 12"), and then down by the starter it goes 4gauge from block to batt.
    Mar 2009
    mich
    85
    728
    My '85 has a ground on the left fender well, on a bracket that's made for it, just behind the jump-start box. It was not-so-good shape when I bought the car, and I replaced the bolt and nuts with stainless hardware. Grounds can sure cause a lot of problems when they get crappy.
  11. Remove Advertisements
