Vacuum leak somewhere inside the dash
Results 1 to 9 of 9
HT4100 4.1, 4.5, 4.9 Discussion, Vacuum leak somewhere inside the dash in Cadillac Engine Discussion; Hey everyone how are you I fixed one vacuum leak at the pcv valve and have another somewhere behind the ...
    mike93 is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Cadillac sedan deville
    Sep 2009
    Media, Pennsylvania
    25
    281
    Hey everyone how are you I fixed one vacuum leak at the pcv valve and have another somewhere behind the dash anyone have this poblem and know where it's coming from before I tear everything apart? thanks
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Re: Vacuum leak somewhere inside the dash
    Can you estimate as to WHERE behind the dash? There are a few vacuum operated items back there including the climate control and parking brake release...
    Sep 2009
    Media, Pennsylvania
    25
    281
    It's like somewhere around the radio or ashtray in that area
    68
    81,883
    Snoop around down there with a stethoscope. A vacuum leak will sound like a hurricane.
    Sep 2009
    Media, Pennsylvania
    25
    281
    ok and yeah when your in the car with the radio low you can really hear it
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    Probably a leak at the HVAC control unit. Outlet selection is typically controlled by a tangle of vacuum lines.
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    A length of hose, like 3/8" fuel hose etc works good to listen for localized leaks. Just be careful with your ears!!
    Sep 2009
    Media, Pennsylvania
    25
    281
    Ok thanks it's wierd because when i have the deforsters on the car idles erratic and could that be why I don't have heat?
    ehall's Avatar
    Aug 2007
    Southern Maryland
    1,883
    I haven't looked at the FSM but typically the outlet baffles are controlled by vacuum harness from the HVAC control unit. If the baffle for the defroster selection is broken then it could suck air into the intake (vacuum is created when pistons pull air and fuel into combustion chamber), and this could cause erratic idling as the MAP sensor tried to adjust for changes in air pressure. I wouldn't think the vacuum draw would be that high (typically the HVAC control knocks it down quite a bit) but if it's around 5 hg inches then it certainly could. Only way to know for sure is put a vacuum tester on the harness and see what happens--they cost $20ish at any parts store, behind the counter with other testing tools.
  12. Remove Advertisements
