Results 1 to 4 of 4
Thread: Failed emissions
    timmytoolman is offline Cadillac Owners Member
    Automobile(s): 1990 fleetwood
    Jan 2010
    58
    9
    Failed emissions
    Took my '90 Fleetwood-4.5l for emissions test and failed the idle test with more than 4.5% CO. Any suggestions as to why it is so rich at idle while it passed the asm test with flying colours?
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    Re: Failed emissions
    Best guess, engine temperature not reaching normal. Normal is a 195 degree thermostat and a running temp around 205 to 210 degrees. inefficient cat converter as well a possibility.
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    It's running rich because the computer is telling it to. Could be any number of inputs, most likely is that the O2 is fouled. Could also be a leak in the exhaust that makes the O2 think the car is running lean. Simpler end of the scale is borken coolant sensor or thermostat making the computer think that the coolant is staying cold too long so the computer tries to help the engine heat up. Could be a leaking injector too.
    Also possible that if it's been rich for a long time that you've burnt out the catalytic converter so get that checked.
  5. #4
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Post all the numbers off the report.
    When you say it passed the ASM test but failed at idle, do you mean it received an ASM test AND a two speed idle?
    Maybe you are saying it passed the 25 and 15 mph but failed at idle?
    Lots of things can cause issues at idle that might not show up under load.
    I'd need to see the rest of the readings to really take a guess though.
    Even then, on a car that old it might require a lot of money to fix....
  • You may not post replies
