1993 Cadillac Deville 4.9L computer problem (ISC problem continued)
Results 1 to 6 of 6
HT4100 4.1, 4.5, 4.9 Discussion, 1993 Cadillac Deville 4.9L computer problem (ISC problem continued) in Cadillac Engine Discussion; So I continued this in another post since the problem is obviously not what I had originally thought... so I ...
    rumgool is offline Cadillac Owners Member
    Automobile(s): 1993 Cadillac Deville Sixty Special Edition
    Mar 2008
    Gainesville
    22
    So I continued this in another post since the problem is obviously not what I had originally thought... so I installed a new ECM and catalytic converter after having driveability issues to the point of stalling. Car ran great after installing the new computer, but the 3rd or 4th time I ran the car after doing so... I got my service engine and vehicle light giving me an F32 error (bad connection between BCM and ECM). My speedometer was also not functional (just showed zero), and the car drove like it had no computer.... First off, is there anything I need to do with the ECM after installing (reset computer on console, reset something else), or do I have a grounding issue, and if so, why now? Also when I unplug and reinstall battery, it works fine the first crank, but the second it fails again... sigh...
    HUF's Avatar
    HUF
    HUF is online now Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 118,*** miles
    Dec 2005
    MA
    58
    2,134
    Re: 1993 Cadillac Deville 4.9L computer problem (ISC problem continued)
    Have you installed correct PROM on the new ECM?
    Mar 2008
    Gainesville
    22
    yea... i just had a loose battery terminal... seems to work fine now... still seems to run a lil rough, but much improved... hopefully o2 sensor will fix the roughness
    Mar 2008
    Gainesville
    22
    Ground failure again today, had to reset battery cables and again, its fine. Any ideas on accessing ground terminals to check connection and clean connectors? I assume a loose ground connection is the source of my troubles...
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,134
    Quote Originally Posted by rumgool View Post
    There is a ground on the engine block next to the starter. Clean the area, replace the stud (8 mm x 1.25) and the star washer. Another ground location is behind the passenger side headlight assembly.
    Mar 2008
    Gainesville
    22
    thank you very much... i just picked up some ramps today so I will be replacing the O2 sensor, and checking those grounds... I got a new computer(testing to see if the replacement I got was faulty) and it hasn't failed yet, so my problem may be fixed, and may be fixed! I am still going to check of course, though. I'm also thinking about flushing my power steering system. Doesn't seem to bad...
  9. Remove Advertisements
