new Tranny
Results 1 to 13 of 13
HT4100 4.1, 4.5, 4.9 Discussion, new Tranny in Cadillac Engine Discussion; What would it cost to rebuild the Tranny on a 4.1...
    MrDobin is offline Cadillac Owners Fanatic
    Automobile(s): 1985 Cadillac Seville Elegante
    Feb 2009
    27
    222
    new Tranny
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Re: new Tranny
    $1200 - $2000
    Feb 2009
    27
    222
    Re: new Tranny
    Might have just made a one in a lifetime catch. Local guy owns my Seville model and is selling for less than 2k. Going to get it for 1k if one thing is correct... are these transmissions the same?. I am going to buy this seville and swap it for parts if so. Worth it to keep stored and pull out parts as needed I think for 1k.
    Oct 2008
    Palm Bay, FL
    2,024
    Re: new Tranny
    You have a THM325-4L. 1986 - 90 have a THM440 (aka 4T60). 1991 and up use a 4T60-E.
    What year is the potential buy?
    Feb 2009
    27
    222
    Re: new Tranny
    An 84 with all same including 4100. I'm going to pick up a 96 Deville though instead. It has only 99k on it and for the same cost it would be for me to pick up this second seville and swap parts. Not worth it. the northstar maintained will get me another 100k and this 4100 is likely to need further work.
    Feb 2009
    27
    222
    Re: new Tranny
    So I took it into the shop to check the tranny out..... and nothing. The fluid is clean, doesnt smell, and on a test drive around the mechanics found no issues period shifting. I am going to have the system flushed though for the sake of being sure and checking the pan. Still baffled as to why the thing got stuck in overdrive/high gear that day. Now I see subsequently that made the fluid bubble and freak me out. Just not sure what would cause a momentary stick in transmission. Will update if it goes to hell again.
    Oct 2008
    Palm Bay, FL
    2,024
    Re: new Tranny
    Search the forum for 'transmission flush' and read about why it's not a good idea to have it done by a shop.
    The stuck in high gear issue may be the TCC/VCC solenoid sticking in the engaged position - that is if you have one in such an early model... Check for codes.
    Feb 2009
    27
    222
    Re: new Tranny
    No codes. Thus making me more upset before.
    Ill check into that thread.
    Feb 2009
    27
    222
    Re: new Tranny
    Can you direct me to the flush thread, dont see anything on search... or missing it.
    Feb 2009
    27
    222
    Re: new Tranny
    Nevermind spoke to early got it
    Oct 2008
    Palm Bay, FL
    2,024
    Re: new Tranny
    There are ALOT of driveability issues that don't set codes, especially in OBD-1 cars like ours. On a pre-'91 caddy, the computer has little involvement in the transmission's operation. And tolerances for the fail conditions are rather wide. Most of the time, the issue has to be pretty bad before a code will set.
    Feb 2009
    27
    222
    Re: new Tranny
    Yea. I figured as much. I am just puzzled as the down and up shifts are fine but this day it stuck in high. I suppose come spring(assuming I keep it low miles use) I can put new solenoids in. I would fear tranny failure but it has had zero issues till the "stick" and even then it wasnt missing it was just flying right into the top gear acceleration. Will see.
    Feb 2009
    27
    222
    Re: new Tranny
    So the update....
    Took it into the shop I have trusted for our work in the past(guy gave my mom a 1200 job with parts free due to financial issue, nice owner need i say more). They drove it around, took a look. Drum roll.... tranny is not fried but it needs fluid changing, with a conditioner, as well as a minimal amount of part and labor to correct a wearing on the shift to 2nd. The theory we drew, this mechanic owned a similar build caddy and did 10 years of tranny work so I have faith hah. Our theory is it stuck into second given linkage issues etc. then when i popped it in and out of gears it adjusted for the time being. Other than the tires and alignment... I am quite glad this was me being paranoid and not an 1800 dollar issue to rebuild. Ill get the details from him when I get the car and repost.
  16. Remove Advertisements
