93 deville problems
Results 1 to 8 of 8
HT4100 4.1, 4.5, 4.9 Discussion, 93 deville problems in Cadillac Engine Discussion; Hi everyone it's me again i think i figured out why the car is bogging down i got a 70 ...
    mike93 is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Cadillac sedan deville
    Sep 2009
    Media, Pennsylvania
    26
    281
    93 deville problems
    Hi everyone it's me again i think i figured out why the car is bogging down i got a 70 code intermittent tps fault so i think that's what my problem is also the power steering line is leaking how hard to put new power steering line? also when you tap the gas lightly u feel the motor jump bad motor mount maybe?
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,117
    Re: 93 deville problems
    Quote Originally Posted by mike93 View Post
    Connect an ohmmeter to the TPS and watch the resistance while lifting the trottle lever. It should change smoothly. If not, replace and follow the adjustment procedure.
    Powersteering line (one connected to the PS gear? if so, must be rusted) is very tricky to put back. My advice: as soon as you take the original one out, put it back. Otherwise you will be figuring out how to do that for a long time.
    Engine jumping. Check out the rubber bushing in the torque mount connected to the top of the radiator cover (aka "dog bone").
    Sep 2009
    Media, Pennsylvania
    26
    281
    Ok thanks HUF the line is leaking a lil and ill check the tps and motor mount i have the fsm so ill check the power steering line in the book
    Sep 2009
    Media, Pennsylvania
    26
    281
    Also I forgot to say the parking brake cable is sticking I need help on what to do about that please help
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,117
    Well, take the rear wheels off and see what's going on when you apply and release the parking brake.
    Sep 2009
    Media, Pennsylvania
    26
    281
    Ok will do thanks huf
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Correct your TPS code before replacing motor mounts. The faulty TPS could be causing your "jumping"...
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    The front parking brake cable is usually a problem when rarely used. I had to lube mine under the dash where it connects to the pedal, and below the body where it comes out of it's housing. The lube worked it's way into the housing when I worked the brake off & on a few times, and became OK again.
  11. Remove Advertisements
