Distributor removal and install on 85 rwd ht4100
Results 1 to 6 of 6
HT4100 4.1, 4.5, 4.9 Discussion, Distributor removal and install on 85 rwd ht4100 in Cadillac Engine Discussion; I have recently redone an 85 rwd ht4100 and the distributor had already removed before I got the car. Purchased ...
    dhuberasu's Avatar
    dhuberasu is offline Cadillac Owners Member
    Automobile(s): Cadillac 1985 fleetwood brougham
    Feb 2008
    bartlett, tn outside memphis
    31
    Purchased rebuilt long-block and I fully assembled the motor before putting in car. Here is the tough part..I had to remove distributor after installing the motor in the car. Now...getting the distributor in is easy and can get a hold down clamp on it but can't start the nut.
    I also don't know if I have the stock distributor clamp..is there a special one that allows the clamp and nut to be installed before distributor is installed?
    Can tell I need the special tool though to tighten it once I get it on.
    thanks
    david
    Dave S Texas's Avatar
    Dave S Texas is offline Cadillac Owners Enthusiast
    Automobile(s): '87 Coupe DeVille 4.1L FWD(New engine '08) 1981 F100 '03FXDL
    May 2008
    Austin(area), Tx
    73
    876
    Re: Distributor removal and install on 85 rwd ht4100
    I feel your pain. BTDT just about 1yr ago this week. I bought a 13mm/15mm distributor wrench from Summit Racing(W1186)....$10 delivered. What a difference the correct tool makes! I was dealing with the 'transition' version of the 4.1. I did not have to remove the clamp&bolt to install the distributor. The clamp has a elongated bolt-hole in mine....
    dhuberasu's Avatar
    Feb 2008
    31
    going to take some pics of this and post....the stud bolt is off to the side of distributor hole and continuing on a radial line there is a "boss" in the casting of the manifold behind the stud....
    I would envision a larger clamp with a slot in it to accommodate the "boss" and stud. All I have in a small one...little larger than quarter and not as big as half-dollar,,,,back edge of clamp catches on front edge of "boss"....just does not seem right.....
    seems like you need to be able to install clamp and nut (loose), then slide clamp back...or tapered edge that as distributor is inserted would push clamp out of way....after fulling inserting distributor....slide clamp inward.....tighten it down....
    thanks
    david
    68
    81,887
    I've had the distributor out of a 4100, but it's been too long ago to remember.
    May 2008
    Austin(area), Tx
    73
    876
    David: your description is exactly how it is on my 4.1, so maybe there was a design change in that clamp. You might try hunting the 'recycle' yards or if you know a parts guy at a dealer, that possible design change can be researched. A machine shop can elongate the clamp-hole.
    dhuberasu's Avatar
    Feb 2008
    31
    thank you gentleman...will post what I do..would like to find proper clamp...will "hit" the place I bought the long block too!!! thanks for the advice!!
    david
  9. Remove Advertisements
