engine shake - 91 el dorado 4.9
Results 1 to 8 of 8
HT4100 4.1, 4.5, 4.9 Discussion, engine shake - 91 el dorado 4.9 in Cadillac Engine Discussion; hello everyone let me first say i'm lovin the forum i have a 91 el dorado. it was having missfires ...
    oaklandish is offline Cadillac Owners Member
    Automobile(s): 1991 el dorado
    Dec 2009
    32
    6
    Questionengine shake - 91 el dorado 4.9
    i have a 91 el dorado. it was having missfires and a high idle. i replaced the fuel injectors and the car idles fine and doesnt miss. but now upon acceleration i feel the engine shake a little bit. it was 10x worse before the new injectors but it still occurs none the less. does anyone have any ideas what could be causing this? i dont think its related to the injectors even though it seemed to lessen the problem when i replaced them.
    the car passed smog today so emissions are running fine. new stuff:
    egr valve and solenoid
    cat converter
    all 8 fuel injectors
    spark plugs, wires, and distributor + rotor
    o2 sensors
    oil and filter
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Re: engine shake - 91 el dorado 4.9
    I have to ask, you never mentioned, did you check for codes?
    Dec 2009
    32
    6
    yes sorry, before i installed the new parts i had a code for egr system failure. now i have no ecm codes. i also forgot to mention, when i rev the gas it doesnt die down as fast as it did before
    Oct 2004
    Oak Creek, WI
    5,609
    You could be looking at a vacuum leak somewhere. Have you checked for any?
    68
    82,064
    Have you cleaned the TB and roded out the EGR tubes inside of it?
    jamesmdx1 is offline Cadillac Owners Fanatic
    Automobile(s): 1988 Coupe Deville, 1991 Coupe Deville, 1989, 1994 Eldorado
    Oct 2005
    NY
    49
    160
    you should disconnect battery to reset computer to idle re-learn after all the cleaning of the TB is done
    Dec 2009
    32
    6
    Quote Originally Posted by jamesmdx1 View Post
    yes i cleaned the throttle body but what is roded out the egr tubes?
    the battery was disconnected yesterday to hook up an amp kit
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Alot of instances where there are no codes, it is a fuel problem. You might want to check the fuel pressure with a test kit. Harbor Freight has them for $20. Also, with the key on and engine off, pull the vacuum hose off of the fuel pressure regulator and look for any signs of fuel inside. There should be none.
  11. Remove Advertisements
