no start probs
Results 1 to 13 of 13
HT4100 4.1, 4.5, 4.9 Discussion, no start probs in Cadillac Engine Discussion; 93 deville, 4.9 no north star car wouldnt start, so i jumped it, acted like it wanted to start, noticed ...
    lowkey is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2008
    33
    28
    Unhappyno start probs
    car wouldnt start, so i jumped it, acted like it wanted to start, noticed that my pulley had rubbed up against one of the battery cables and ate thru it, replaced that, battery was still a little dead, so we jumped it, still wouldnt crank. put my friends battery on and it cranked up just fine. left it running and switched batteries, drove home and killed it, tried to start it immediately after, wouldnt start. bout three hours later walked out to the car and it started just fine...let it sit over night, tried to start and nothing. took battery to walmart for replacement but the batt. tested good. so me and my friend went back to my car tried to jump it, nothing, tried his battery again on my car and got no response. new starter, checked wires they are all good, no anti theft probs, brand new lock cylinder, brand new alternator, brand new neutral saftey switch, everything seems to be fine on check list....i hear the fuel pump kick on...but nothing when i turn the key.....no action from the starter at all, test light shows im getting power to the starter and out....we even pulled the starter off and check it on the battery, tested fine.
    all relays and fuses also check to be fine....
    what do you think it is.?>?>?>?>?>?>?>
    Mark C's Avatar
    Mark C is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Seville STS, 2000 Seville STS
    Jul 2007
    58
    1,693
    Re: no start probs
    Check your ground cable from the block to the battery.
    Aug 2008
    33
    28
    Re: no start probs
    checked all wires all in good standing condition
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    Re: no start probs
    Some GM cars have a "start" fuse in the panel. I believe it's only like a 3 amp fuse, so it must be running an inter-lock relay or ?? Anyway, check the fuse panel for one marked that way.
    Aug 2008
    33
    28
    Re: no start probs
    as stated b4, all fuses and realys are good
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,109
    Re: no start probs
    Can you hear a click from the starter when you turn the key on? Try some 10-20 times see if it starts.
    Aug 2008
    33
    28
    Re: no start probs
    no action at all from the starter when i turn the key, i hear relays clickin but nothing from the starter, funny thing is that when i used my friends batt. the first time it started fine, tried that again and it wouldnt start, nothing from starter
    68
    81,917
    Re: no start probs
    Could the click you hear be the solenoid rather than a relay?
    Aug 2008
    33
    28
    Re: no start probs
    i know for a fact its the relay, i crawled under the car today and crossed the post on the starter, it started up just fine......went to the store and back...started it up 3 or 4 times in a row just fine...about 2 hours later went back out to give it a try...and nothing again...nothing at all.
    68
    81,917
    Re: no start probs
    OK, I think there is a starter enable relay. Look for that.
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,109
    Re: no start probs
    Quote Originally Posted by lowkey View Post
    Try to run a cable from battery positive to the starter positive terminal VERY CAREFULLY, so that the cable would not touch hot exhaust manifold and melt causing short. The positive post of the starter is a 8 mm stud.
    Mar 2009
    mich
    85
    728
    Re: no start probs
    You mentioned a new lock cylinder. That works the push rod going down to the ignition switch on the column. Do you know that the switch itself is OK ? The switch has multiple contacts, like IGN 1, IGN 2 etc, so some relays etc may be getting power, but not always the starter solenoid.
    Just an idea..........
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: no start probs
    Did you check the starter wire with the test light or just the large positive cable? If the start wire lights the test light every time you turn the key then it has to be the starter or solenoid. In that case I would gamble on a rebuilt unit. I say gamble because rebuilds are a 50-50 crap shoot in my experience. If the start wire isn't lighting the test light then it must be a relay.
  16. Remove Advertisements
