E48 Code- EGR FAULT
Results 1 to 6 of 6
HT4100 4.1, 4.5, 4.9 Discussion, E48 Code- EGR FAULT in Cadillac Engine Discussion; I have a egr fault code, when i ran my diagnostic and i'm having a rattle when accelerating, could that ...
    JoJo_Brand_Star is offline Cadillac Owners Member
    Automobile(s): 1987 Cadillac Sedan Deville HT4100
    May 2008
    Austin, Texas
    45
    E48 Code- EGR FAULT
    I have a egr fault code, when i ran my diagnostic and i'm having a rattle when accelerating, could that a bad egr cause it to rattle when accelerating?
    68
    82,064
    Re: E48 Code- EGR FAULT
    Yes.
    May 2008
    Austin, Texas
    45
    Thanks, Ranger!
    I read some things up, so i did a little research on the symptoms from a bad egr valve and it did include that it cause a rattle at acceleration.
    Now, should i take the egr valve apart and clean? or should i just replace the whole egr valve?
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,112
    What is "da rattle"? Is it from engine bay? Does it sound like more mechanical rattle? Say from loose exhaust parts or even cat converter? I will not be surprised at all if after all the playing with the EGR valve the rattle is still there. Have you cleaned well two EGR tubes inside the throttle body under the throttle plates? Looks like you started another link about the same problem. Not a good idea.
    May 2008
    Austin, Texas
    45
    it sound more like a loose rattle to me
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,112
    Quote Originally Posted by JoJo_Brand_Star View Post
    And how does EGR contribute to loose rattle? Have you tried to put it on a hoist and powerbrake instead of guessing? It will cost you $20 and five minutes. You have got two different and not related issues.
  9. Remove Advertisements
