Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Injector cleaner, will it work?
    Lars Langoy is offline Cadillac Owners Member
    Automobile(s): 1989 Allante
    Mar 2007
    11
    Hi
    My 36k mile 1994 DeVille has kinda rough idle, according to the shop manual the only cause of this is clogged injectors.
    Not unlikeliy since the PO was 70 when he purchased the car and had it until his passing this spring, I guess only litle trips to the mall has been made.
    So the big Q is if the liquid injector cleaners will work, or if another approach must be made?
    Regards
    Lars
    behind-bars is offline Cadillac Owners Connoisseur
    Automobile(s): 93 Sedan Deville 4.9L
    Sep 2005
    Texas
    1,005
    Re: Injector cleaner, will it work?
    First I would check for codes using off + warmer and see if it gives you a idea. I do not think clogged injectors are the only cause of a rough idle. Anything that makes the cylinders not fire right could cause it; including clogged injectors, worn out spark plugs or wires, or a old distributor cap to name a few. Cleaning them is worth a try if you feel like it, but I wouldn't rule everything else out and stay focused on the injectors if it doesn't work
    69
    82,278
    While ther may not be many miles on them, the wires ARE 15 years old.
  5. #4
    Mar 2007
    11
    Thank you guys, I will check the codes.
    If the codes does not give me any hint it might only need some
    distanse driving, I guess small trips is not the best.
    I already replaced the plugs, wires, rotor and cap.
    Regards
    Lars
    http://picasaweb.google.com/Cabillac/1994SEDANDeVILLE#
    http://picasaweb.google.com/Cabillac/1975SedanDeVille#
    http://picasaweb.google.com/Cabillac/PreviousOwnedCars#
  6. #5
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    It could be fuel system related such as weak pressure or clogged injectors. I would dump a small bottle of the Lucas Fuel Treatment ("tune-up in a bottle") and see if it helps--that is the best injector cleaner that I've tried then have a shop check for fuel pressure at the rail, replace fuel filter, etc., if problems persist. I would also consider ignition problems since weak spark can produce the same symptoms. Did you gap the plugs or put them in blind?
  7. #6
    Mar 2007
    11
    Hi
    The plugs was supposed to be ungapped, it was bosch platinium with the four points, but it had roug idle prior to all of the parts replacements.
    I replaced the fuel filter today and purchased a bottle of STP injector cleaner, I will take a hour or so roadtrip next week.
    Thanks
    Lars
  8. #7
    69
    82,278
    Quote Originally Posted by Lars Langoy View Post
    Hi
    Thanks
    Lars
    That may be your problem. I'd tank 'em and use A/C Delco plugs. You would not be the first to report problems after using Bosch plugs.
  9. #8
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    He had the problem before the plug change though. Really can't understand why Bosch plugs would not work right,
    even though folks have had problems with them.
  10. #9
    Mar 2007
    11
    Hi all
    Had the Cad for a 100 mile road trip to see if the injectors would clear up.
    After like two hr of driving the engine started to really behave bad and at some point the Service Engine Now came on for app 10 seconds.
    When I finally got home I read the codes, I got: P041 History (No Cam Reference Signal from Ignition Control Module).
    I am positive the code is new, I checked the codes like a couple of weeks ago and there was none.
    So now I have another problem to solve and maybe this also caused the rough idle.
  11. #10
    69
    82,278
    Maybe the hall effect switch has been your problem all along.
  12. #11
    HUF's Avatar
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 118,*** miles
    Dec 2005
    MA
    58
    2,128
    Hi all
    Take the ICM to Advance Autoparts. They have equipment to check it out. It is a $20 easy to remove and install. Do not forget thermoconductive grease, you should apply when installing the module. Some ICM come with packed grease.
  13. #12
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Check the wires and connectors inside the distributor that go to the cam sensor. They get brittle over time and will fall apart in your hands. The code is history so that means the ECM didnt receive a signal from the sensor for 5 seconds or more on a previous ignition cycle. If the engine is running rough while the code is not current, than the cam sensor is probably not causing it. Bad injectors are an all too common issue on these cars.
  14. #13
    Mar 2009
    mich
    85
    728
    Sometimes a car that has set around a lot has more problems than one that is driven regularly.
    One of my partners bought an Olds Cutless for his daughter that was 15 years old, extremely low miles, with the original tires, belts,hoses etc on it. All that stuff failed of course, and other things, within a couple of months.
  15. #14
    Mar 2007
    11
    Hi
    Is it possible to replace the hall effect switch without pulling the distributor?
    The P041 code is History, but I guess bad contact will cause the problems as well?
  16. #15
    69
    82,278
    I think it is, but never had to do it so see what someone who has has to say.
  • You may not post replies
