Injector cleaner, will it work? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
HT4100 4.1, 4.5, 4.9 Discussion, Injector cleaner, will it work? in Cadillac Engine Discussion; Yes, its possible. You'll need a 1/4" box wrench. Like I said, the hall effect switch will not cause your ...
  1. #16
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Re: Injector cleaner, will it work?
    Yes, its possible. You'll need a 1/4" box wrench. Like I said, the hall effect switch will not cause your symptoms UNLESS the code is CURRENT.
  2. #17
    Lars Langoy is offline Cadillac Owners Member
    Automobile(s): 1989 Allante
    Mar 2007
    11
    Re: Hall switch, was: Injector cleaner, will it work?
    Hi all
    A n update on this issue:
    I replaced the hall switch today (and the ICM as well), had the Cad for a little spin afterwards and it seems better now. Hopefully the hall switch was the cause.
    As you can see in the linked picture the old hall switch is very corroded.
    http://picasaweb.google.com/Cabillac...21546205177026
    This is not my daily driver so sometimes it takes saveral days between each time I drive it, but I will post if the problem is still present.
    Thanks to all of you!
    Regards
    Lars in Norway
  3. Remove Advertisements
