4.1 Motor? Rattles/Engine Pinging? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
HT4100 4.1, 4.5, 4.9 Discussion, 4.1 Motor? Rattles/Engine Pinging? in Cadillac Engine Discussion; Jojo, why don't you make a youtube video of the rattling sound when it happens?...
  1. #16
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Re: 4.1 Motor? Rattles/Engine Pinging?
  2. #17
    JoJo_Brand_Star is offline Cadillac Owners Member
    Automobile(s): 1987 Cadillac Sedan Deville HT4100
    May 2008
    Austin, Texas
    45
    When the car is running, you don't hear it unless you put it into drive then accelerate. Now while in park, i hold the brake down and the accelerator at the same time and i heard the noise still.
  3. #18
    HUF's Avatar
    HUF
    HUF is online now Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 118,*** miles
    Dec 2005
    MA
    58
    2,130
    Quote Originally Posted by JoJo_Brand_Star View Post
    Do you hear the noise when you accelerate backwards (in reverse)? Just be careful.
    Did you get off road recently? Or hit something with the underbody?
  5. #19
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    Maybe you have a bad engine mount ? Just a thought. Even a cracked flex plate on the engine could rattle.
  6. #20
    May 2008
    Austin, Texas
    45
    that just may be the issue, my motor mounts are bad.
    I found that out like a few weeks ago, that i needed to replace them.
  7. #21
    daniel58 is offline Cadillac Owners Fanatic
    Automobile(s): 58 Coupe Deville, 77 Coupe deville, 90 Deville
    Sep 2009
    183
    My vote would be to replace the EGR valve, I had this same problem with an 83 Eldo 4100 and a new EGR took care of it.
  8. #22
    May 2008
    Austin, Texas
    45
    I noitce a few days ago, my egr code came up when i ran my diagnostic.
    But i change all my fuses, and it went away.
    So i figure my egr is good, since the codes aren't coming up now.
    Should i still replaced it, anyway?
  9. #23
    Mar 2009
    mich
    85
    728
    You changed all the fuses? Why? If you had the ECM power off, you likely erased the EGR fault that came up. It will be back if the EGR is a problem. There is no knock sensor on that engine system, so the EGR valve or it's passages in the manifold my be a problem like mentioned above.
  10. #24
    May 2008
    Austin, Texas
    45
    Well...
    Until then whenever it appears again, i will just get egr work done to it.
  11. Remove Advertisements
