Results 1 to 6 of 6
Thread: 4.9 Upper a/c compressor bracket
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Does anyone have a picture or diagram of the bracket that mounts from the top of the a/c compressor to the P/S pump bracket?
    Oct 2008
    Palm Bay, FL
    2,024
    Re: 4.9 Upper a/c compressor bracket
    Anyone with a 91-95 4.9 Seville, Eldorado, or DeVille factory service manual?
    Oct 2008
    Palm Bay, FL
    2,024
    Bump :d
  5. #4
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,607
    Sorry Sevillia, I haven't been on much lately as I am sick with pneumonia. I'll go out and snap a shot in a few minutes.
  6. #5
    Oct 2004
    Oak Creek, WI
    5,607
    Alright Sevillian, I took a couple shots but I'm not sure how much they will help as it's a tight spot to get a shot. These are looking DOWN at the AC compressor.
    that long black bar is the top mount for the AC compressor, which bolts to the aluminum bracket above behind the timing cover, under the PS pump. Easily seen directly behind the plug wire in the picture.
  7. #6
    Oct 2008
    Palm Bay, FL
    2,024
    Awesome! Thanks dude! I cant see the lower end of it, Is it a straight bar from end to end? I'm hoping I can make one in case I cant find one. If it's straight, I can flatten the two ends of a chunk of 3/4 EMT....
    It actually looks like I can remove just the smog pulley and the 4.9 belt will slide right by it... It just depends on how big the pulley mount turns out to be.
    Anyways, thanks for taking the time to snap the pic! That's a big help.
  • You may not post replies
