| Re: 1993 Sedan Deville Transmission Swap You're looking for a 4t60E from any 91 to 95 4.9 cadillac. Northstar cars use a slightly different trans (4t80E) if you get a trans out of an STS or an Eldo ETC, the final drive ratio will be higher(3.33) vs 2.98 for base model sedans. You will have more acceleration off the line but higher rpm and less mpg at highway speeds with an STS or ETC trans. They're pretty rare anyways so its not likely that you will find one... Just make sure you get a non-northstar trans from any 91 - 95 caddy and it will work.
