| HT4100 4.1, 4.5, 4.9 This forum is to discuss the newer aluminum block Cadillac engines. | Cadillac Forums: Judgement Call - No Heat 93 Deville
10-30-09, 10:35 PM
| | Cadillac Owners Member Cadillac(s): 1993 Sedan Deville | | Join Date: Oct 2003 Location: Central Illinois | | | Judgement Call - No Heat 93 Deville Okay - let's start off I want NO SYMPATHY here. It is what it is. Anyway......I have a 93 Deville owned in family since new. Now it's at a tick below 90k miles. From a "need" standpoint, I dont need the car...I have another daily driver and a different "backup". This is my 3rd car. I like it...and think its sort of a respect factor to my parents/grandparents to take care ot it. Normally I do my own stuff, but work took precedence - so whatever.
Fall 2008 I took my car to a local "trusted" shop to have my coolant system for its annual flush/refill of coolant and supplement tabs. The car was bought Nov 1992 and has been a ritual since. It got a clean bill of health and we moved on. Car garaged. My parents know the owner of the shop I took it to, but he's pretty disconnected from the day to day operations of the shop.
Come late Winter 2008 (2 mo later) ...little heat. Take it back to the same shop, they say the heater core must be clogged and needs to be replaced. Per my request, they reluctantly did a more intensive flush with the same result. I let it go until recently.
Between the "Little Heat" and now, I learned I had Leukimia, advanced stage. I have to think the owner of the shop knows, as he and my parents talk often.
Now...I have everything under control healthwise and things are looking better. Work has slowed down and since I've been feeling a lot better, I swapped out the core last weekend.
Still, no (or very very little) heat.
Did some reading here and find info on the "T". Pop the hood and find the T is REVERSED. The restrictor is on the drivers side of the T.
I switched the T and viola....HEAT!!
so I ran it by the owner of the before-mentioned shop. Owner brings his Cadillac mechanic over. Said mechanic says there's no way the T could have been reversed for a year. If it was, the car would be toast. It would have overheated LONG before now. It will ONLY cool properly if the T was right and he would have immediately noticed that.
My question is...............how possible is it for
A - something have taken place to generate interest in said shop performing core replacement (estimate $600)
B - Something fishy taken place at the shop to initiate my interest in having them perform the repair.
Please advise - I'm not out to judge anyone - just looking for honest opions. |
10-30-09, 10:57 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Judgement Call - No Heat 93 Deville I can't answer your questions, but the ONLY thing that reversing that T will do is just what happened, minimal heat out put. |
10-30-09, 11:02 PM
| | Cadillac Owners Fanatic Cadillac(s): '85 FWD fleetwood, '93 fleetwood Bro | | Join Date: Mar 2009 Location: mich Age: 78 | | | Re: Judgement Call - No Heat 93 Deville Since my car is older, I don't specifically know about the "T", but if it's in the heater coolant flow circuit, I don't understand how it could affect engine cooling, and the "toast" statement. There folks here who are experienced with the T fitting, and they will have the correct answer. My impression is that the so-called Cadillac mechanic is trying to cover his a$$.  |
10-31-09, 12:01 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 1995 FWB 87,*** 1991 Seville 175,000 SOLD | | Join Date: Dec 2005 Location: MA Age: 50 | | | Re: Judgement Call - No Heat 93 Deville Those guys are definitely BSing you. Stay away. Coolant change does not require touching the T. So it WAS reversed on purpose, unless it was cracked and needed to be replaced, and someone made an honest mistake. Quoting $600 for heater core replacement is way too much. The core is about $30 and it is pretty much a DIY job, though not a favorite one.
Nothing is wrong with your Caddy. Do not worry about anything. They also might be interested in making you sell them the "defective" car for next to nothing.
And lastly, I wish you full and speedy recovery. |
10-31-09, 02:50 AM
| | Cadillac Owners Fanatic Cadillac(s): '85 FWD fleetwood, '93 fleetwood Bro | | Join Date: Mar 2009 Location: mich Age: 78 | | | Re: Judgement Call - No Heat 93 Deville :d:d |
10-31-09, 10:05 AM
| | Cadillac Owners Fanatic Cadillac(s): 1993 Eldorado, 4.9L, 200k miles | | | | | Re: Judgement Call - No Heat 93 Deville Quote:
Originally Posted by Lance Allison Come late Winter 2008 (2 mo later) ...little heat. | This implies that the car did have heat for 2 months after the coolant flush. The "T"'s position must have been changed while doing other work during that 2 month period. |
11-01-09, 08:58 AM
| | Cadillac Owners Member Cadillac(s): Deville | | Join Date: Oct 2009 Age: 41 | | | Re: Judgement Call - No Heat 93 Deville The "T" has an arrow pointing coolant flow direction. It must point TOWARD the passenger side of the car. I recommend replacing it and orienting correctly. Also make sure you get all the air of the system and never check the coolant again by removing the radiator cap. Always use the overlflow. |
11-01-09, 06:02 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1995 FWB 87,*** 1991 Seville 175,000 SOLD | | Join Date: Dec 2005 Location: MA Age: 50 | | | Re: Judgement Call - No Heat 93 Deville Quote:
Originally Posted by chrisalcorn The "T" has an arrow pointing coolant flow direction. It must point TOWARD the passenger side of the car. I recommend replacing it and orienting correctly. Also make sure you get all the air of the system and never check the coolant again by removing the radiator cap. Always use the overlflow. | It DOES make sense to check the coolant inside the radiator when it is COLD, because in some cases the hose connecting the reservoir to the radiator neck gets clogged, so that one may think there is sufficient coolant in the system while the radiator is half-empty. |
11-01-09, 11:29 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Judgement Call - No Heat 93 Deville |
11-04-09, 08:06 PM
| | Cadillac Owners Member Cadillac(s): 1993 Sedan Deville | | Join Date: Oct 2003 Location: Central Illinois | | | Re: Judgement Call - No Heat 93 Deville In a nutshell, I went ahead and swapped the heater core, as I assume its original. Plus it was time for the annual coolant drain. Got a OEM core from Rockauto for a couple of bucks, also a new "T". Using the FSM and help from this forum,the job took me maybe 2.5 hrs (don't laugh). Filled it with a 60/40 mix of green coolant and added the GM seal tabs. Purged the air from the system and all seems well now. Thanks for being here, the wealth of knowledge and opinion from experience is invaluable. |
11-04-09, 11:55 PM
| | Cadillac Owners Enthusiast Cadillac(s): 93 Sedan Deville 4.9L | | Join Date: Sep 2005 Location: Texas | | | Re: Judgement Call - No Heat 93 Deville Your 2.5 puts me to shame lol, Mine took the better part of the day and I didn't even change the coolant lol. Its been over 3 weeks and the cuts I got on my hand taking the hoses off the core still have not fully healed. Though if I had to do it again I feel that it would take less then an hour |
11-05-09, 12:27 AM
Originally Posted by Lance Allison In a nutshell, I went ahead and swapped the heater core, as I assume its original. Plus it was time for the annual coolant drain. Got a OEM core from Rockauto for a couple of bucks, also a new "T". Using the FSM and help from this forum,the job took me maybe 2.5 hrs (don't laugh). Filled it with a 60/40 mix of green coolant and added the GM seal tabs. Purged the air from the system and all seems well now. Thanks for being here, the wealth of knowledge and opinion from experience is invaluable. | Check the coolant level after two-three engine heating and cooling cycles. It took me more than 2.5 hours to finish the job. Good job.
11-05-09, 11:40 AM
| | Cadillac Owners Member Cadillac(s): 1993 Sedan Deville | | Join Date: Oct 2003 Location: Central Illinois | | | Re: Judgement Call - No Heat 93 Deville Will do on the coolant level. I've added to the overflow bottle twice so far. I think what saved a lot of time was having the correct hose spring clamp pliers with remote handles for compressing the clamp. Without those, it would have taken a whole lot longer. |
11-05-09, 12:09 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1995 FWB 87,*** 1991 Seville 175,000 SOLD | | Join Date: Dec 2005 Location: MA Age: 50 | | | Re: Judgement Call - No Heat 93 Deville By the way, in the future you can siphon coolant with about 1/4" pvc tube through the neck of the radiator. That way you will get more than a gallon of coolant out of system. Just push the tube all the way to the bottom of the radiator side tank. No mess and takes 15 minutes. |
11-20-09, 12:37 PM
| | Cadillac Owners Member Cadillac(s): 1995 sedan deville | | | | | Re: Judgement Call - No Heat 93 Deville I din't have any heat in my 95 Deville and everything else looked fine. My husband told me to change this thing in front of the radiator thats about the size of your finger. ( He calls its a temperature prode. I don't know what it is) well its by the hood latch and is electrical. I did and not I have some heat. If anyone knows what it is I would like to know it that changing it made any sense, but I have heat now. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
